Adjusting Camber in the front
Old Aug 31, 2012 | 09:11 PM
Dankrohn's Avatar
Hi guys,
My friend has an '05 coupe and his front tires are feathering. He took it to a tire shop to see if they could adjust the camber and/or alignment and they said they cannot adjust the camber on his current suspension and that he will need new shocks and struts. Does this sound right? Should he be able to adjust his camber?
Thanks!
Dan
Old Aug 31, 2012 | 09:22 PM
gary c's Avatar
If your friend has a high mileage '05 coupe there's a very good chance the shop was correct. With our Infinities there's some tow adjustment and very little camber adjustment which is why we install camber kits. If this shop knew what to look for there's a good chance he also needs bushing along with a few other suspension pieces....Gary
Old Sep 1, 2012 | 12:10 AM
totopo's Avatar
Originally Posted by Dankrohn
Hi guys,
Thanks!
Dan
That is correct. For the front, there is only a toe bolt. The camber changes minimally when they fix the toe, but for all intents and purposes, oem front camber is not adjustable. (it's a modified double a-arm, not mcphearson strut). The rear does have a toe bolt and a camber bolt.
Old Sep 1, 2012 | 12:17 AM
herrschaft's Avatar
Have your friend look into aftermarket replacement bushings first, if the struts themselves were truly bad there would be more problems then just alignment. New bushings might alleviate the need for a camber kit.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
paolojericho11
Sep 11, 2015 07:08 AM
derres
Aug 28, 2015 03:27 PM
jimNC
Jul 25, 2015 05:47 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
