Exhaust with metallic noise...
Old Jan 18, 2005 | 08:25 PM
maz's Avatar
maz
Exclamation Exhaust with metallic noise...
All of a sudden start getting this metallic noise what appears to come from the exhaust system, only happens when car is cold (been 3 to max of 25 degrees here lately) for about 1-3 minutes then goes away. Noise is loud enough to over-scream the exhaust. Taking it to a dealer on Thursday night, so they can listen to it on Friday morning when it’s called. Just wanted to run it by you Geers to see if any of you experienced that before.
Also, when going through a touchless high pressure car wash, passenger door is leaking. It’s not bad, but seal definitely lets the water in. Dealer will check into that as well.
That’s sucks, car only has 1700 miles… my 97 bimmer never had little problems like that, nor big once. Japanese quality?! Just a little upset….
Good news, I am getting a loaner…hehehe you know where I am going. Will try to get a coup, or an FX… Or a sedan..well it doesn’t matter, I will be killing it and practicing my MM driving
Old Jan 18, 2005 | 11:13 PM
P_Diddy's Avatar
I've been getting a metallic rattle/vibration on cold start-ups. I think it's a heat shield. I'm not sure if we are talking about the same thing though. here's a link to a thread I started Linkie
Old Jan 18, 2005 | 11:16 PM
Gee Im Fast's Avatar
I get it too on cold start ups...anyone know about this?
Old Jan 19, 2005 | 01:36 PM
Crazi4Speed's Avatar
I have the same issue, didnt goto the dealer about it, since i havent heard it for sometime now and its really freezing here...
Old Jan 21, 2005 | 04:19 PM
maz's Avatar
maz
Ok, just got a message from assistant service manager of Infiniti of Cincinnati, they’re keeping the car till Monday at least to have somebody else (a supertech? ) to listen to the exhaust…. Will do the follow up when hear back from them.
So far they treated me very well. This Matt guy been pretty helpful
Old Jan 21, 2005 | 04:31 PM
1Gig's Avatar
Are you guys getting white or black exhaust on the exhaust tips? If your tips are getting white, I think your cars are running too lean and may have to reset your ECUs. My friend had the same problem and got white exhaust tips. We corrected the problem by resetting the ECU? If your tips are black, then it's something else that is causing the problem.
Old Jan 21, 2005 | 09:29 PM
My car is Brand new with only 150 miles on it.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Video Share
Jan 31, 2017 04:00 PM
prinny
Nov 22, 2015 11:07 PM
dcsbh1
Oct 1, 2015 03:15 PM
