cnc short shifter knob removal
Old Sep 21, 2012 | 02:40 PM
ipad's Avatar
cnc short shifter **** removal
I bought the G with the short shifter already installed. I want to wrap the shift ****, and i am just making sure that the **** just twists off and i don't need to take extra precautions.
~Thanks.
Old Sep 22, 2012 | 04:01 AM
Revo's Avatar
If your car is a 6MT, which is sounds like it is given that your **** is twist on/off, you need to pop up the plastic trim piece that constitutes the lower part of the center console (ash tray + shifter area). It pops up pretty easily.
Then, you need to grab a hold of the shift lever with a pair of vise grips or pliers prior to spinning off the ****. The reason is that if your shift **** is screwed on tightly, you might twist the entire shifter assembly and unscrew it from where it attaches to the tranny, which would not be good.
Freeman186
Sep 6, 2023 10:07 AM
Danielek
May 1, 2022 01:28 PM
Thebaws11
Nov 30, 2016 12:54 PM
TNRocker
Sep 21, 2015 08:36 AM
