Radiator cooling issue
Old Sep 25, 2012 | 06:15 PM
Muzariazz's Avatar
Delete This Thread.
Delete This Thread.
Old Sep 25, 2012 | 06:51 PM
Lone Wolf's Avatar
Are you saying the fans are loud when they come on? They are not quite by any means.
Old Sep 25, 2012 | 10:25 PM
Muzariazz's Avatar
The fans are quiet but when I put my car in park after driving they are loud for a while, but still I checked my radiator fluid when it was cooled down, there was no fluid from opening the cap but the fluid was in the reserve tank? And my car hasn't overheated or the gauge hasn't got hot...
Old Sep 26, 2012 | 12:12 PM
Muzariazz's Avatar
so today i went to check outside and there is some fluid on the ground from the reserve tank, but still fluid in it? maybe theres a leak in the reserve tank? not sure where this is coming from, would really appreciate the help
Old Sep 27, 2012 | 11:29 AM
Muzariazz's Avatar
Checked again and now the fluid seems to be gone from the reserve tank and the fluid levels are normal, can't seem to figure out what's going on here
Old Sep 27, 2012 | 11:51 AM
vipernick913's Avatar
How's the temperature on the gauge? I had a similar issue with my car overheating and radiator fluid leaked all under the hood leading to the ground.
Old Sep 27, 2012 | 01:40 PM
Talley9's Avatar
What did you drive before?
I came from a 1.8L Civic to the 3.5L G35 myself and also notice that after sitting in park for a few seconds after a drive, the fans really kick on. I wasn't used to it because the Civic didn't, as well as every other 4cyl I had.
My thoughts are that while you're in motion, the air flow is enough to keep your engine cool, but once you stop, it's sort of playing catch up to cool it back down???
VW does it right... the fan remains on even after shutting the car off to ensure the engine is cooled down, that freaked me out the first few times it happened also.
Could be nothing.
Old Sep 28, 2012 | 10:39 AM
Muzariazz's Avatar
Temp guage went up yesterday but didnt overheat or anything, i have no clue what the issue is, im going to take it into the shop today and see whats going on
Old Sep 28, 2012 | 06:28 PM
Gisele's Avatar
ROFL I remember this. In front of the beach. Good workout that day.
Old Sep 28, 2012 | 06:29 PM
Gisele's Avatar
Originally Posted by Muzariazz
Hey guys,
I recenetly just purchased a 2004 G35 Coupe, White Exterior, Tan Interior with navigation, im having a few issues, i got a radiator flush and the guy filled everything up to where its supposed to be, i drove it for like 20 miles and i looked at it and there is radiator reserve is full of fluid, the car temp guage is normal, no overheating or anything but the fans go on and its loud when i put it back in park, any ideas on what could be going on? ive searched a feIw threads but couldnt find the answer.
might be your radiator fan. Call Infiniti you should still have it under warranty. The was a recall on these.
Old Sep 28, 2012 | 08:30 PM
gary c's Avatar
With your coupe in park and the fans going faster sounds like fan or wiring/sensor issue. Qualified Nissan mechanic should be able to locate the issue by testing the circuits....Gary
Old Sep 29, 2012 | 12:08 AM
smoovarrowhead's Avatar
My guess would be the mechanic may have overfilled the system a tad too much causing the overflow to seep the excess fluid...Also any fluctuation (rise) in temperature could mean air trapped in the cooling system. Even qualified mechanics can improperly bleed the system as it has to be done repeatedly sometimes to get all air out. I would rule this out first before pointing towards the fan(s).
Old Sep 29, 2012 | 03:36 AM
Muzariazz's Avatar
i doubt its still under warranty, car has 109K, but if there was a recall, shouldnt it be on the carfax report? and how can i check for any recalls the 2004 G35's have that i should get in to get taken care of, thanks... as far as the temp guage, its gone up once but hasnt done it again
Old Sep 29, 2012 | 11:19 AM
Gisele's Avatar
The carfax does not show everything. It's a big misconception. Just call your local Infiniti dealer. Tell them you want to register the car u fee your name and give them your VIN#. Good luck
Check this out
https://g35driver.com/forums/showthread.php?t=316580
Old Sep 30, 2012 | 12:33 PM
Muzariazz's Avatar
Check this out
https://g35driver.com/forums/g35-coupe-v35-2003-07/316580-04-07-g35-coupes-extended-warranty-radiator-fan-motors.html
So just hit up infiniti, tell them i wanna register the car, give em my name and VIN and they will let me know if i have any open recalls that should be taken care of? is it free to register with them? thanks alot brotha.
