My G is clicking :/ HELP!
Old Oct 5, 2012 | 10:48 AM
thenexthendrix's Avatar
Exclamation My G is clicking :/ HELP!
So recently my G has started this clicking/rattling near the front of my car. This noise only happens when I accelerate or decelerate. It's super loud and drives me crazy! I went to the shop I get my car tuned at and had them take a look at it. They said it's more than likely something loose (a spring) on my clutch. What do y'all think??
Old Oct 5, 2012 | 03:25 PM
TemjinX2's Avatar
You sure it's not wheel bearings?
Old Oct 5, 2012 | 04:40 PM
it might be. im going to get it checked out from a nissan dealership and they want $100 JUST to check it out. ludacris. anyway it sounds like something it loose inside my engine. I recently just got long tube headers installed so thats my guess but I will check the bearings
Old Oct 6, 2012 | 06:07 AM
TemjinX2's Avatar
here's a very simple test you can do yourself to test your wheel bearings. Its for a s65 amg mercedes but the test is the same since there both rwd.
http://youtu.be/BcmQYR9sASQ
A wheel bearing replacement is relatively easy and cheap to fix as a diy but its very messy. Also always get oem wheel bearings, do not get the aftermarket ones. Some aftermarket wheel bearings will mess up your traction control systems. I learned this the hard way on my mercedes.
Diode Dynamics
Accessories-Vendor
39
Nov 30, 2021 02:28 PM
Detailed Image
Sep 18, 2015 03:43 PM
Detailed Image
Sep 17, 2015 07:38 AM
