INFINITI G35 OEM Smart Key Remote Fob Key
Old Oct 9, 2012 | 02:12 PM
Muzariazz's Avatar
Delete This Thread.
Delete This Thread.
Old Oct 9, 2012 | 09:06 PM
06G35Coupe94's Avatar
I just need this one question answered. when you go to start your car, do you have to use your key? Like for my 06 I dont need to use my key to start. I just sit and turn the ignition.
Old Oct 9, 2012 | 09:15 PM
Muzariazz's Avatar
Yeah i have to put the key in the ignition and turn it on, so im guessing the smart key wont work for this then, will the second option i posted work? the one where the key flips out with the 4 remote buttons, where would i have to get it cut and how would i have to get it programmed? thanks.
Old Oct 9, 2012 | 10:30 PM
The first one you posted is the OEM one. Thats the one I have and it has a key inside of it. I would recommend getting that one.
Old Oct 10, 2012 | 01:31 PM
Muzariazz's Avatar
just ordered
http://www.ebay.com/itm/NISSAN-INFIN...5fa171&vxp=mtr
would be alot easier to flip the key every time instead of taking it out the back from the OEM one even though that looks alot nicer, now how would i be able to program this and set it up? thanks
Old Oct 10, 2012 | 02:28 PM
Michaelh90's Avatar
here i was also looking into it.. the 07 fob looks much better. i had the folding key but i didnt like it its to big..
https://g35driver.com/forums/audio-v...-smartkey.html
Old Oct 10, 2012 | 02:32 PM
Originally Posted by Muzariazz
just ordered
Have to take it to the dealership. Cost around $150-$200 to program it
Old Oct 10, 2012 | 04:33 PM
Muzariazz's Avatar
damn! thats expensive just to program it? no way we can do it ourselves?
Old Oct 10, 2012 | 04:39 PM
Michaelh90's Avatar
Old Oct 10, 2012 | 04:52 PM
dukehotty's Avatar
You should shop around. I got different prices from two different Infiniti Dealerships. I ended up paying $120. Just make sure you have BOTH Key fobs with you since they have to reprogram both of them. Maybe try Nissan too?
Muzariazz's Avatar
Another question, it says it comes with all the electronics in the car and what so, now ive been reading about the transpoder in the key, will i have to move my original one over or can that be programmed with the new key that already comes with one?
Old Oct 10, 2012 | 05:34 PM
dukehotty's Avatar
The intelligent key and the regular key fob are different. The intelligent key actually allows you to start the car without a physical key in the hole. I think that is why you can not program it yourself.
Old Oct 10, 2012 | 05:37 PM
dukehotty's Avatar
I just looked at your ebay links. If your car did not come with an Intelligent key, then I don't think it will work with your car. Stick to the same style you already have.
Old Oct 10, 2012 | 05:58 PM
Michaelh90's Avatar
i dont think it comes with a chip. if it comes with a new chip it has to be program at the dealer. when i bought mine i had to get the key cut which was like 20 bucks at a locksmith and then take the chip off the old key and put it on the new one.
Old Oct 10, 2012 | 06:02 PM
Muzariazz's Avatar
the listing for the product says "KEY INCLUDES ALL THE OEM ELECTRONICS INSIDE, INCLUDING THE TRANSPONDER CHIP AND REMOTE !!!"
ill try to program it once it comes in, thanks alot guys
