Camber kit with S-tech - necessary?
Hey everyone,
Quick question:
I’m planning to install TEIN S-Tech springs on my coupe.
Should I get a camber kit as well? The drop is minimal (1.2” front | 0.9” rear)
If I do need one, can someone direct me to a good brand/model and a distributor?
Thanks.
Quick question:
Thanks.
my camber in the front was -1.68º so i had to get front a-arms the rears aligned fine tho. I got the kinetix front camber kit but its starting to make noise. I heard 350EVO has some coming out soon
I had the S-tech's on my coupe but took them off for the winter.
Definitely will need front and rear camber correction if you don't want to eat your tires up.
I'm thinking about the Cusco because it looks like a good part and is more reasonably priced than most of the competition.
The kinetix is cheaper but doesn't look as well built.
you need the whole $219 kit - the arms for camber corrections and the bolt for toe correction...
boostelevator
Engine - Power Adders
Sep 9, 2015 05:56 PM
