My Various Coupe Newbie & Mod Questions - Please Help
Old Jan 29, 2013 | 11:39 PM
  #61
LxV Socal's Avatar
Originally Posted by Leksikon
Ok, I think I understand what you're saying. Unfortunately I also think you're a little wrong.
First, changing tires doesn't require a new alignment. In some cases if you went with insanely different tire sizes, it might be needed, but even then that's a stretch. The alignment is done for your suspension, tire problems are a result of the suspension only, not the other way around. So if you do an alignment and it's good, you can switch tires and wheels every day for the rest of your life and if you don't touch the suspension, they'll all wear the same.
Next, the car pulling to one side isn't uncommon, my car is actually doing that slightly now that I've had it aligned (and looking at the sheet, everything is actually in spec). Most new cars tend to pull right as a safety mechanism. Road crowns exaggerate that effect slightly. You can have all sorts of ****ed up alignment specs and have your car not pull to one side. I can show you my old tires if you like, they all looked like your front with the belts showing because my toe was way out of spec (as I knew it would be). But the car diidn't pull to either side, ever. Still ate threw tires like a fat kid in a candy store.
Last, an alignment is much cheaper than a new set of tires. If you do it right the first time you'll be able to keep tires on the car for more than 4 months at a time. Like I said above, you may not feel a problem that will eat your tires. That's why I recommended reusing the old ones for a bit to find out if you've fixed it before you destroy some brand new rubber.
Feel free to blow any or all of this off, just trying to help man. I've destroyed more tires than I should have because I was never aligned. In my case it was because I kept changing components, ride height, etc. and I knew it was going to happen and didn't care. If you want your **** to work right, it's easy.
Okay that makes sense.well do you think there is any chance of my tire blowing up on me if I flip them? I drive 60 miles daily and I CAN'T risk being late to work
Old Jan 29, 2013 | 11:52 PM
  #62
Frankieg35's Avatar
Dont chance it and get a tire, that one is toast..
Old Jan 30, 2013 | 12:35 AM
  #63
Xet's Avatar
Xet
Ask for a print out of pre and post and let us know what the specs are
Old Jan 30, 2013 | 02:52 AM
  #64
LxV Socal's Avatar
Will do!
Old Jan 30, 2013 | 11:51 AM
  #65
JOKER's Avatar
CLUB MODERATOR
You need to check your bushings before you do an alignment.
As Leksikon has mentioned. If bad bushings is a part of your bad toe wear, you will continue getting that wear even after alignment. If you have a good alignment tech, he'll inspect the bushing or any other parts that could contribute to a bad tire wear and will not do your alignment if he finds a part that will continue to contribute to your tire wear even after alignment.
So if you can, jack up the car and check your control arm bushings your self to see if they have cracks in them.
Old Jan 30, 2013 | 12:24 PM
  #66
The Stimulation's Avatar
Mentioned the bushings earlier. OP, I've posted in the So Cal shop directory thread where there's a really good alignment shop and they're lowered friendly and will charge 60 bucks. They will tell you if a bushing is out. Ask them to check first before doing an alignment. Although they can do the alignment and if you have them do the install with the new part (They won't install the bushing), they will give you a free alignment. I ended up having R&J replace my bushing and getting another alignment.
Old Jan 30, 2013 | 12:37 PM
  #67
bluedevils95's Avatar
Originally Posted by LxV Socal
Yes I am in need of a camber kit.Which one do you have?
I forget what i buy but i think it's Ichiba. I still have the box at home. Do you want it?
Old Jan 30, 2013 | 01:45 PM
  #68
LxV Socal's Avatar
Keep stock wheels or trade for xxr 521?
I got offered to trade rims for some xxr 521 18" in black and putting $600 on top.(my tires are gone and his tires have 75% tread left) Im trying to look for pictures of the 18" on a g35 in black but was not able to find one...all were 20"
Here is how my car currently looks.Name:  mycar_zps2abba50b.jpg
Trade or no trade? what do you guys think
Old Jan 30, 2013 | 01:57 PM
  #69
JaE35's Avatar
Moderator
G35 Sedan
I say no, keep your wheels
Old Jan 30, 2013 | 02:01 PM
  #70
Polishthrust's Avatar
Dont drop $600 on a downgrade. Use that money for some oem Rays + spacers.
Old Jan 30, 2013 | 02:13 PM
  #71
LxV Socal's Avatar
Hmmm I was thinking of doing just that.What size spacers would you recommend? 15mm front 20mm back?
all I have left to do is get a new look on the wheels and get a lip or nismo bumper and ill be happy
Old Jan 30, 2013 | 02:26 PM
  #72
JaE35's Avatar
Moderator
G35 Sedan
Rays are definitely a better option..size of spacers will depend on your ride height..get the wheels first and then do a measurement to the fender
Old Jan 30, 2013 | 02:34 PM
  #73
LxV Socal's Avatar
Gotcha.thanks!
Old Jan 30, 2013 | 03:01 PM
  #74
LoSt180's Avatar
Most common sizes are 20mm front 25mm rear. Lately I've been seeing people get aggressive in the rear and run a 32mm.
Old Jan 30, 2013 | 07:04 PM
  #75
ThatOneDude's Avatar
They are technically a downgrade but look way better than OEM if you're lookin' for something cheap.
Old Pics of my car:
