Help with 03 G35 coupe
Old Nov 20, 2012 | 10:05 AM
sedwick's Avatar
Just bought an 03 at auction a couple months ago. Not familiar with Infinity cars but have learned a lot from this site. The car has several mods that I can see, the engine is very strong uses very little oil. Surprised at how fast this car is.
The front end is wore out and I'm in the process of gathering parts. It needs to be raise up a few inches, barely clears speed bumps around here. My 16y/o daughter is driving it. From what I can tell it has D-spec coil overs on the front, the front left one the shaft is bent so I'm putting stock Monroe shocks back on it. The springs on the front have two white marks and the ones on the back have two red marks...Are these stock springs? Will they work on these Monroe struts? If not which ones would bring it up about an inch or two? Will replacing the ball joints and bushings raise it up any? I just need to get the front a little higher off the ground and get the steering and suspension tightened up.
From what I can tell it has stainless headers, Borla exhaust, D-spec coilovers with adj. extenders in the trunk, Stillen strut brace on the rear, engine dampeners, engine ground mod, and have no idea if anything else has been done to the engine...
I'll try to figure out how to get some pictures uploaded
Old Nov 20, 2012 | 10:22 AM
jstudrawa's Avatar
https://g35driver.com/forums/brakes-...reference.html
For spring ID.
Others much more knowledgable than me will chime in shortly I am sure.
And welcome to the club.
Old Nov 20, 2012 | 10:28 AM
gary c's Avatar
Since you're not versed in our Infiniti's post a few pic so we can better help you. This G doesn't have coilovers but struts. If they're D Specs the company name is Tokico and far superior to anything Monroe ever made. You can buy parts from our MARKETPLACE at a very good price and immediate delivery, struts would be under vendor suspension.
We need pic so we're not guessing at what you may have or not....Gary
Old Nov 20, 2012 | 10:41 AM
sedwick's Avatar
Thanks for the quick reply, and the link. I just need the car up off the ground.
I get an error when I try to upload it, it appears my attachment is too big. JPEG image 2.72mb
Any help with getting pictures up would be much appreciated
R350k5
Oct 1, 2015 08:41 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Steering & Suspension
Aug 3, 2015 02:44 PM
laksjd84
Jul 24, 2015 05:12 PM
