Trunk issue, HELp!
Old Nov 30, 2012 | 11:02 AM
2011lsv's Avatar
Trunk issue, HELp!
My remote will lock and unlock my locks but will not open the truck, any idea why??
Old Nov 30, 2012 | 11:51 AM
xTazx's Avatar
I've been doing some reading BC I have the same issue. I haven't looked into it but check your fuse and if that's not the problem check the tunk release harness. Some people have had wires break.
Old Nov 30, 2012 | 03:29 PM
Ejoe19's Avatar
Have you had any work done to the trunk lately? The trunk's positioning is very sensitive. If its off even just a hair it may not close right or the latch may not have enough room to open/close like it should.
I did a test fit of my Strafe trunk and it took me nearly 2 hours to be able to have it positioned right so that the latch would catch like its supposed to. A real PITA...
Old Nov 30, 2012 | 05:00 PM
Deepdiver's Avatar
sounds like your trunk actuator lock is out. I believe the factory part number is 84630CM40A. But you may want to double check with Phil over at Grubbs.
Old Dec 3, 2012 | 12:57 PM
2011lsv's Avatar
The button under the dash works to open the trunk, where is the fuse at?
Old Dec 3, 2012 | 01:46 PM
2011lsv's Avatar
I just called the dealer, they said it is not the fuse because the system would not work at all, so they say its a bad remote. I believe it because I just tried my panic button, and it does not work either. I also replaced the remote battery just to make sure.
Old Dec 16, 2012 | 08:32 PM
tszyuenc's Avatar
I have the same problem before and i found out the wires was broken. go open you trunk from inside and see is that the problem.
Old Dec 16, 2012 | 08:34 PM
tszyuenc's Avatar
you can open your trunk by put down your back seat and go in, find a "hook" that was on the top of the trunk and pull it
tal1412
Nov 28, 2022 09:25 AM
G35VSHNG37
Oct 25, 2015 08:43 PM
Jusseth
Aug 24, 2015 05:24 PM
mryogi
Aug 20, 2015 04:10 PM
linedr89
Aug 17, 2015 05:11 PM
