Help headlights
Old Dec 3, 2012 | 01:27 PM
bpd_g35's Avatar
Help headlights
so i put some headlights covers on my G(adhesives backs). i removed them. now i have the glue left. i tried goo gone it made it worest turned white all over. can someone help me abd give advise on how to remove this glue n get them back clear.,
Old Dec 3, 2012 | 02:20 PM
hurleyguys's Avatar
use the goo gone and take the rest of the glue off. then get some polish and an orbital buffer (or by hand but will take a lot longer) then buff it till it is clear. i usually throw some wax on top to help protect the plastic. depending on how bad the plastic is you might have to use a little bit of compound before the polish.
Old Dec 3, 2012 | 02:22 PM
That's G's Avatar
Oops! is a great product for adhesive removal also. +1 for polishing them afterwards as well.
Old Dec 3, 2012 | 02:26 PM
bpd_g35's Avatar
it seems to me it was taking the plastic off also. it may just be that glue.
Old Dec 3, 2012 | 02:27 PM
bpd_g35's Avatar
with the goo gone or oops. is there anything else required to get the glue off. like sanding it off or just a cloth
Old Dec 3, 2012 | 02:29 PM
That's G's Avatar
Just use a cloth and let the product sit on the adhesive for a little bit. Once saturated, it should wipe right off.
Old Dec 3, 2012 | 02:30 PM
bpd_g35's Avatar
will try it
Old Dec 3, 2012 | 02:43 PM
VMRWheels's Avatar
Try 3M All Purpose Adhesive Cleaner. Put some on a microfiber towel and just rub the areas lightly. It usually works pretty well to clean off any oils, adhesives, etc.
Just be advised that it's probably not the best for plastics and whatnot, so don't go spraying it all over the place. As I mentioned, apply it to a towel and rub the towel on the headlight.
Old Dec 3, 2012 | 02:57 PM
That's G's Avatar
+1
I forgot about 3M. I've used this also with good results.
Old Dec 3, 2012 | 03:01 PM
VMRWheels's Avatar
That's what we use to make sure the surface on the barrel of our wheels is clean for the weights when doing wheel/tire combos.
Old Dec 3, 2012 | 03:18 PM
Darkstar752's Avatar
DO NOT USE 3M.
It WILL destroy the headlight plastic, but it sounds like the plastic already has permanent damage from the Goo Gone. OP, use a car-specific tar remover next time such as Tarminator. You can sand and polish the headlights, and if that doesn't work you have to start shopping for new headlights.
Old Dec 5, 2012 | 09:28 AM
bpd_g35's Avatar
ok found outthe best way to fix my own problem which was to take it to a professional . but for what they did could have done my self. a light sander and buffer with conpound and sealer. came right out and back to new look.
Old Dec 5, 2012 | 09:46 AM
gary c's Avatar
We were just trying to save you some $$ since most of us have been in your situation. Googone would have worked had you saturated a micro towel and worked slowly. Make sure you wax those headlight with some quality wax so they stay clear....Gary
Old Dec 5, 2012 | 12:27 PM
bpd_g35's Avatar
i was only out of 50 dollars but now ive learned how to do them
jeffbdye
Jun 1, 2018 03:51 PM
Picture Share
Feb 4, 2018 12:41 PM
9tray turbo
Sep 29, 2015 10:22 PM
Batfinity
Lights
Sep 27, 2015 12:29 AM
