Motordyne Plenum 5/16 spacer issue
Well I have a 2006 g35 coupe and I just installed the basic plenum spacer which was so simple to do. It took about 30 minutes so I put everything back together and everything was fine. It pulls harder so my butt dyno tells me but here is the issue. About 20-30 miles later ses light comes on. So I reset the ecu then like 20 miles later the sescomes on again.Everything was fine before the spacer so I go and get the code pulled at autozone and I got a P0172 fuel injection system too rich bank 1. So im puzzled i also have a short ram intake that was on before the spacer. Idle is fine everything is normal except the ses code.
Thats weird, I replaced just about every intake/exhaust component with bolt-ons when N/A and I have yet to reset the ECU via the pedal method, always just disconnected the battery. No SES light ever came on.
