Parking/License plate light question
Old Dec 9, 2012 | 04:36 PM
Sleeepy's Avatar
I bought an 04 coupe recently and the parking lights are out, so are the license plate lights. I wanted to know if they're on the same fuse or if they are completely different.
All 4 are out and I don't know if its just a coincidence.
Old Dec 9, 2012 | 04:42 PM
Lone Wolf's Avatar
I don't know if the parking and license plates share the same fuse, but, try replacing the license plates lights first since they are so easy to replace. Then go from there.
Old Dec 9, 2012 | 04:51 PM
jutn35's Avatar
G35 Coupe
time to switch to LED
Old Dec 9, 2012 | 04:52 PM
Lone Wolf's Avatar
^^ +1. If you do decide to get some LED's OP, grab some super white ones from Henry at Statik.
Old Dec 9, 2012 | 07:36 PM
gary c's Avatar
Great idea....^....Henry's one of the good guys here on DRIVER, but I'd check all your fuses first! You could install the LEDs and still have them not work.
Gary
Old Dec 9, 2012 | 09:05 PM
PlastiDippinG's Avatar
had the same problem, thanks to ^ GARY C i found the second (hidden) fuse box, you have to remove your battery cover, and then there is the second fuse box right behind it, i believe it is the first fuse on the top that runs the daytime lights,but if the fuse it out there is a sure fire way to tell, your hvac control lights as well as your tail lights (running,not break lights) will also be out. Your corner lens lights will be out as well.
Old Dec 12, 2012 | 09:02 PM
Osa713's Avatar
Same thing happened to me
jsimonk
Dec 22, 2023 03:49 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Nick_M
Aug 3, 2015 11:08 PM
julian.dion
Jul 29, 2015 09:16 AM
nervseele
Jul 17, 2015 11:21 PM
