help will replacement motor fit
Old Dec 16, 2012 | 09:35 AM
Shack's Avatar
Hello, I am new to this site , I hope I am in the correct area for this posting . I just recently bought a 2004 g35 2door couple autimatic with 70,000 kilometer on it, the car itself is perfect.
I bought the car as is, the car turns over but will not start, I had the car inspected and they said the the timing had jumped a tooth causing it to damage the valve. In other words I was told to buy a new motor.
So I just recently bought a 2005 g35 four door with the six speed . Now the big question here does this motor bolt up to my 2004 with or without many changes. I am new to owing a infiniti . I love this car and want to get it up and running. Please any infomation will help
Old Dec 16, 2012 | 01:02 PM
gary c's Avatar
There's no reason the VQ motor from the sedan won't bolt right up to your coupe swaping out a few parts for the trans and ECU....Gary
Old Dec 16, 2012 | 01:08 PM
Darkstar752's Avatar
Yea that motor won't work unless you swap the ECU. You bought a Rev-up motor, your original is a non-rev
Old Dec 16, 2012 | 03:33 PM
Shack's Avatar
motor replacement
Thanks for the good news that my motor will fit, you mentioned that I need to take the ECU unit from the 2005 and put it in the 2004 due to the rev motor, Do i need to remove the wiring harness as well from the 2005 or will the ECU just swap over. thanks again for your help
Old Dec 16, 2012 | 03:35 PM
Shack's Avatar
installing 2005 motor into a 2004
Old Dec 17, 2012 | 06:05 PM
superchargedg's Avatar
You will also have to get rid of the pilot bearing that a 6mtuses and a 5at dosent...easily done.
Old Dec 18, 2012 | 06:00 PM
partyman66's Avatar
Why not swap in the 6-speed tranny while you're at it? Sure, you'll have to do some fab-work to put in a clutch pedal, etc. and may need a different driveshaft, but I would think you'd enjoy it more if you already know how to drive a MT. You should already have most of the parts you'd need if you bough a whole G35 Sedan A/T.
Hasanbaloch
Feb 29, 2024 08:45 PM
jsimonk
Dec 22, 2023 03:49 PM
mcneil_g35
Aug 5, 2015 12:03 PM
will091195
Jul 27, 2015 09:19 PM
justgotg35
Jul 19, 2015 12:33 PM
