Difference between coupe sport and non sport suspension?
Old Jan 11, 2013 | 02:48 PM
jstudrawa's Avatar
Originally Posted by akogan79
I didn't mean to sound ignorant but my main question was if the suspension has a height difference between sport and non sport and that link you posted didn't have any info on that. Just don't tell me to search next time because your search didn't show me what I'm looking for.
There is, as determined by wheel/tire combos. There was a another thread listing the exact measurements, but the 17" rims are the lowest fender-to-ground distance. Some minimal distance like .25 inches I think.
I'll see if I can find it.
Grab a tape measure and measure from the ground to the center of the wheel arch and compare to:
From the Factory Service Manual (ie FSM)
Wheelarch Height (Unladen = full tank of gas, spare tire, jack etc in stock locations)
With 17"
Front: 691 mm (27.20 in)
Rear: 702 mm (27.64 in)
With 18"
Front: 694 mm (27.32 in)
Rear: 710 mm (27.95 in)
With 19"
Front: 699 mm (27.52 in)
These measurements are from the ground to the high point of the arch (centered on the wheel hub).
Old Jan 11, 2013 | 03:14 PM
akogan79's Avatar
Originally Posted by rsingerG35
I don't think there is a difference. It is essentially the same suspension only stiffer and bigger sway bars. The wheels/tires might affect ride height.
Thank you. That's the answer I was looking for. I guess it is just a bit stiffer then non sport.
Old Jan 11, 2013 | 03:16 PM
akogan79's Avatar
With 17"
With 18"
With 19"
Great info here. Thanks. Exactly what I need.
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
R350k5
Oct 1, 2015 08:41 PM
xplosive1
Aug 1, 2015 03:01 AM
multimut
Canada
Jul 26, 2015 08:43 PM
itschuckster
Jul 25, 2015 08:07 AM
