Dead Battery Concerns
Old Jan 26, 2013 | 04:30 PM
rsingerG35's Avatar
Well, I have my wife taking care of my car while i'm deployed. As of today she said the battery has died. Is there any harm to it sitting for a couple weeks on a dead battery? I read all this stuff about having to get the ECU to relearn or the idle.
Old Jan 26, 2013 | 04:32 PM
dexthurr21's Avatar
is it totally dead like the radio does not work?
Old Jan 26, 2013 | 05:31 PM
rsingerG35's Avatar
No completely dead. Car just clicks.
Old Jan 26, 2013 | 07:01 PM
dexthurr21's Avatar
that happened to my car for not using it for 2 months. you will not have problem with the ecu unless the battery totally dies. my suggestion is have it jumpstart and at least start and let it run for 5 mins every other day or just leave it like that until you come back!
Old Jan 26, 2013 | 09:12 PM
rsingerG35's Avatar
So the car can't live without power? It doesn't re-learn on its own?
My wife managed to get it jump started and drove it for a bit.
Old Jan 26, 2013 | 10:24 PM
dexthurr21's Avatar
well the battery just have enough power to open up the doors and electronics, but not enough to crank it. l left my car sitting for 2 months and the battery was discharge.
After that i left it sitting for a couple of weeks but i'm starting it up every other day! I'm using my car now and have no problems with my battery.
Old Jan 26, 2013 | 10:25 PM
dexthurr21's Avatar
btw, how long will it be sitting?
Old Jan 27, 2013 | 12:44 PM
partyman66's Avatar
There should be no harm done to the car by leaving it with a dead battery. However, if you let that battery sit dead for a long time, there's a pretty good chance that you'll have to replace it with a new battery when you get back. If you have your wife jump the car or use a battery charger to get it back up to charge, you can probably salvage the existing battery... depending on how old it is. Anytime you run a car battery down all the way, you're doing damage to it. Try to have the Mrs. start the car like once a week to keep it healthy, or have her buy you a trickle charger and hook it up to the car.
Old Jan 27, 2013 | 01:15 PM
rsingerG35's Avatar
Sweet thanks. The battery is a couple years old. Innerstate brand. I am having her start it twice a week to keep it solid for a couple more weeks.
Old Jan 27, 2013 | 01:16 PM
rsingerG35's Avatar
About 4 months.
Old Jan 27, 2013 | 04:32 PM
dexthurr21's Avatar
About 4 months.
that's a long time. have your wife use it sometimes.
Old Jan 27, 2013 | 04:37 PM
rsingerG35's Avatar
Agreed. So it won't have any effects on the ecu or other computers If it doesn't have any power?
Old Jan 27, 2013 | 05:01 PM
dexthurr21's Avatar
not unless you remove the negative battery terminal or the battery fully dies, the ecu will not reset.
Old Jan 28, 2013 | 01:40 AM
2K6G35c's Avatar
You just need to buy a new battery. Simple as that. My battery went out when the car was four years old, jumpstarted it with my Maxima, went straight to the auto parts store and dropped a C-note on a new one. If it's only the battery that's gone on your G be happy and replace it, problem solved.
Old Jan 28, 2013 | 05:22 AM
rsingerG35's Avatar
Any suggestions on a brand of battery?
