ARC V1 Oil Catch Can Install and questions.....
Old Feb 22, 2013 | 01:22 PM
420OG35's Avatar
First off anything is possible. All you need is the right tool. Second of all. I'm running a catch can with my breather. Works awesome. I can open my hood after a nice run and see faint smoke come out of it. So I know it's doing what it's supposed to.
No matter if you have a VQ or not. A catch can is a catch can. Wether arc or eBay.
If you go with a breather can. Make sure you tap into the right spot. I have mine coming from my Pcv valve and coming back into the vacuum line that originally went into the charge pipe. I'm boosted so I don't have that vacuum line going into anything
Or if you just want to go to any other line. You just have to buy a check valve from advanced
Old Feb 22, 2013 | 01:30 PM
VQ Johnny's Avatar
Originally Posted by serges
Hmm I seen na 350z use it tho I guess I dont get it? (
I'm pretty sure they either run a line to the ground to avoid the oil smell, or just block it. But for some reason I still think you can hook the bigger line on the other side into it as well, isn't that how the v2 can and the g35 can work?
Old Feb 22, 2013 | 01:33 PM
serges's Avatar
I just need a diagram or someone that can point me in the right direction to make it work on my revup... I know skys the limit so I can mod it and mock it up to make it work... just dont know where to begin...
Old Feb 22, 2013 | 01:34 PM
gary c's Avatar
Go on my350z theres plenty of people using these gary??? I bought this right here on driver... im not sure if its vented but I know aam used to mod these to fit fi set ups.... its a arc v1 oil catch can... its official had a nice decal on it but making another one and then polishing it all up either for use or fs...
Ok serges did a SEARCH on the Z Forum, there's a post on installing this can but it requires plugging/welding all the holes on top and welding in a new bung. Just because it's possible to install doesn't mean you should! For what they cost it's not going to look worth a damn!
Originally Posted by SAMzG35
What's the point of a catch can serges?
SAMz, basically the catch cans keep keeps the blow by oil out of your plenum so it doesn't end up in your motor mixed with gas. When I discovered this back in '05 I immediately installed the HomeDepot can to collect that unwanted oil before I bought a real can....they work!
Gary
Old Feb 22, 2013 | 01:56 PM
serges's Avatar
Gary I can make this can work trust me just need a location to weld a flange or bung...
Why be like everyone else gary when u can be different lol.... hey if u guys r using pop bottles and hone depot remedys im pretty sure I can make this work..
Old Feb 22, 2013 | 01:57 PM
SAMzG35's Avatar
G35
Thanks Gary. How much oil does it collect? Like how many ml every 1k miles?
I remember when I installed my plenum spacer I noticed some oil residue, nothing serious though. I might consider one.
Also what did you buy Gary for a real can?
Old Feb 22, 2013 | 02:29 PM
serges's Avatar
Update: just got the hole filled on the breather vent..
Old Feb 22, 2013 | 05:46 PM
gary c's Avatar
Thanks Gary. How much oil does it collect? Like how many ml every 1k miles? I empty my catch can twice a year, total for the year I get 1/8 cup. Glad to know that isn't running thru my engine or caked on top my valves.
I'm using a C6 polished Vette catch can due to is small diameter. Size is always a consideration when buying a catch can, we don't have a lot of room. Check out my garage, there's a pic of my engine compartment and the catch can....Gary
Old Feb 22, 2013 | 06:48 PM
serges's Avatar
Theoretically this can should work if I add another port near the mount? If no one chimes in im just gunna sell it here or on my 350z
Old Feb 22, 2013 | 07:06 PM
VQ Johnny's Avatar
yea 2 bungs would work if you blocked off that breather, pcv to can and can to plenum
EDIT
found this too but its with a vortec, it seem the breather was an issue hence the V2 can, but seems to work fine with FI as is so IDK
http://my350z.com/forum/forced-induc...n-install.html
Old Feb 22, 2013 | 07:34 PM
serges's Avatar
Yea seen that thread too I dont know what to do....
Old Feb 22, 2013 | 07:42 PM
VQ Johnny's Avatar
could you use the breather to tap the pcv, block the other holes and use the other bung to the plenum
Old Feb 22, 2013 | 07:47 PM
serges's Avatar
Not sure how to hook this up... im new to the occ game not sure where to hook up what really...
Old Feb 22, 2013 | 07:52 PM
VQ Johnny's Avatar
it should go in between the pcv and the plenum, a line from the pcv to the can and another line from the can to the plenum
Old Feb 22, 2013 | 07:53 PM
  #30
VQ Johnny's Avatar
https://g35driver.com/forums/engine-...catch-can.html
