Power seat won't move back and forth?
Old Mar 18, 2013 | 03:10 AM
Kicknshift's Avatar
Originally Posted by 350GT_
I hear you can manually move it if you open the seat up. That could be a temporary or even permanent fix.
I could really use a guide on this. It would feel odd driving my new G home when I have to sloutch my whole body into the clutch because the seat is so far back.
Anybody know how to move it manually so I can atleast be comfortable while I attempted to fix it.
Old Mar 19, 2013 | 08:18 PM
Ben35's Avatar
How can I access the switches? The screws going into the seat are blocked from access by the center console, which I have yet to find a way to remove. My passenger seat reclines, but doesn't like to come back up.
Old Mar 19, 2013 | 08:24 PM
redonblack35's Avatar
This is currently an issue with both of my front seats... weak nissan motors fml
Old Mar 19, 2013 | 10:10 PM
partyman66's Avatar
Take front facia off the seat bottom (two screws). You should be able to see the motor that propels the seat forwards and backwards. Three screws on each side hold the drive motor to seat rails. Remove the six screws and unplug the motor and remove it. You can manually adjust the seat with a 10mm wrench. You will need to alternate sides to keep seat moving rearward evenly. I'd put the motor back in immediately after you're happy with it's new adjustment rather than leaving it out, but maybe leave the cover off until you get everything sorted out (for easier access, should you need to get at it again).
Old Mar 19, 2013 | 11:01 PM
Kicknshift's Avatar
Awsome man thanks a bunch! Now I can drive it home comfortably if I end up buying it.
Old Apr 3, 2013 | 01:37 AM
dineth00i30's Avatar
Do you guys think its safe for more to spray some liquid wrench on to one of my buttons to see if it will help?
Old Apr 3, 2013 | 02:37 AM
350GT_'s Avatar
I'm not sure as I've never used liquid wrench. I would assume that it would be since they seem to do mostly the same stuff, but the ingredients may differ. WD-40 appears to work and doesn't seem to have harmed anything so I would just go and pick up a can.
Old Apr 3, 2013 | 12:15 PM
Ok, thanks.
Old Sep 26, 2013 | 11:24 AM
Smontiel123's Avatar
Possible fix for power seats
My 2003 infiniti g35 6mt power seats stopped working, at the same time. I thought it was the motors but weird both of them messed up at the same time?? Nah apparently, it was a fuse. it was located in the driver side inside the the car. I noticed that the fuse powers the seats and makes the constant beeping noise when you have your keys in the ignition and the door open. So if your car doesn't make that noise and your seats don't work it's probably a fuse.
Hope this helps! And if you need a pic of the message please tell me! I'll be glad to help
Old Sep 26, 2013 | 02:23 PM
350GT_'s Avatar
Great info!
Old Sep 26, 2013 | 02:57 PM
rsingerG35's Avatar
So today I went to see a G off craigslist and all went well except a few minor issues.
The issue that was the Worst was the drivers power seat won't move back and forth, and also the oher direction which I'm not familiar with. It will move the seat up and down but nothing other than that. I was curious if this is a simple fix or could be an expensive fix And if anybody has hhad this issue and resolved it?
What year is your G?
Old Aug 4, 2016 | 12:19 AM
MarioG85's Avatar
Is there a video tutorial on how to do this? What would I need to use the 10mm wrench on to make the seat move back?
Old Aug 4, 2016 | 06:55 AM
Blue Dream's Avatar
I drove ttrank's car solo
Not that I know of. When you get the cover off and the motor out you will see the 10mm nuts you need to turn to adjust the seat.
Old Mar 14, 2018 | 12:03 AM
RnG's Avatar
RnG
I have a gear issue (motor making a noise). do u have a link to a web site that shows how to repair?
RA102223
Intake & Exhaust
Jul 25, 2015 01:03 PM
apintojr
Jul 23, 2015 10:52 AM
brian_z
Jul 20, 2015 01:30 AM
