Clutch Break in Procedure!
Old Mar 23, 2013 | 09:13 PM
canehdian_guy's Avatar
Hey guys,
So I just got my new clutch installed and have researched the break in period a ton, but I'm unsure of the safest way to break it in.
I know that the purpose of the break in period is to safely create the heat required to mate the clutch disc and flywheel together, and that the heat required to mate the clutch and flywheel together is created by shifting gears.
If you are in stop and go traffic, would that constant shifting create too much heat to allow the clutch to safely break in?
Also can all of the driving be done at one time or does it need to the period of a lot of trips?
BMW's set their clutch break in times according to number of shifts. If I were to drive through residential areas shifting a lot, could I shorten my break in period?
Thanks a lot guys! I really wanna break her in tonight and dont want to break her tonight!
Old Mar 24, 2013 | 11:51 AM
spgoode's Avatar
I've owned about ten cars with manual transmissions and never heard of breaking in a clutch.
Old Mar 24, 2013 | 12:18 PM
dofu's Avatar
20 Year Member
What I've learned is that breaking in a clutch would be like breaking your brake pads - you want to first get rid of the manufacturing coating which you would normally sand off of the brake pads, and then you want to wear it down so it is even according to the rotors, or in this case, the flywheel.
How I've learned to break in the clutch is essentially to ride the clutch just a bit. Give the motor some revs and then drop the clutch just a little slowly without riding the clutch too much. Do this a few times and you can even get the clutch to "feel" the way you want it to.
But I'm not sure if this is something I would suggest you do by yourself without seeing how it's done since you can mess up the clutch while doing this if you're not careful.
Old Mar 24, 2013 | 08:28 PM
ss284's Avatar
^I did as said above. Well put, just as breaking in break pads.
A clutch will surface quickly to your flywheel, whether thats your original, or new.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
prinny
Nov 22, 2015 11:07 PM
AL8782
Oct 3, 2015 10:26 AM
jbmw002
Sep 10, 2015 12:54 AM
