front finder hit 2'' drop
Old Apr 10, 2013 | 12:56 PM
Koohsky's Avatar
hi guys sory to ask this but i low my G for 2'' with 19''' wheel and i have problem with the front fender because my tires hit it some time when i drive. the front tire is 235/45/19 so i wonder what kind of tire i could get so that i have some spec from the fender?
Old Apr 10, 2013 | 03:00 PM
OBsessed's Avatar
235/45/19 is too tall. Reduce it to 235/35 or 225/35 if it's hitting inside, if it's hitting the outside / fender lip area you'll need some negative camber to move the top of the wheel inward.
Don't adjust your front tire sizes without measuring against your rear tire sizes. If your outer diameter changes too much from front to back you'll have VDC problems. Start with the camber and see where that gets you. Post a picture so the next person doesn't have to take random guesses at what might help and can actually see what your problem is.
Old Apr 10, 2013 | 06:13 PM
Xet's Avatar
Xet
45??? Your tire is way too tall. You'll have to do some measurements to see exactly what you need, depending on what your wheel offsets are you could prob just size down the tire and put some more camber in and roll your fenders and be fine - unless you are running something extremely aggressive, which I doubt...
Old Apr 11, 2013 | 12:29 AM
Koohsky's Avatar
if i get the new tire should i get all 4 or just the front one ? but thanks a lot thats helpful
Old Apr 11, 2013 | 12:30 AM
Koohsky's Avatar
hey thanks so much
Old Apr 11, 2013 | 12:34 AM
Koohsky's Avatar
thanks
Old Apr 11, 2013 | 01:21 PM
Xet's Avatar
Xet
What tire sizes are you running all around and what are you rim specs?
Old Apr 14, 2013 | 01:33 PM
420OG35's Avatar
Def 35s. You should be fine. Although 2in is a lot she said lol
Tukeeg35
18 Inch
Aug 25, 2015 06:45 PM
kinetek
Aug 3, 2015 04:25 PM
richmc
Jul 26, 2015 08:13 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
Soumilg
Jul 18, 2015 12:33 PM
