missing a part and questions
Old Apr 11, 2013 | 12:41 AM
dinojuice's Avatar
Hello Yess I'm a noob . Idk if this post should b here or not
I doo my research always ,most i have got from this site
I think I have a POP charger but I'm missing the part that goes onto the radiator to the heat shield ? Does someone kno if Or Were can I buy this part from. (Link would b helpful ) thanks.
Nd another question my drive shaft is leaking transmission oil from I think the yoke , I need to kno if its the drive shaft that's going bad Or is it just the seal/s . If just seals what are the part numbers for that can i get at autozone ?
Also if i install hfc and leave the stock Y pipes and stock mufler would it still sound stock?
Mabey this would help some Lol ( 04 g35 coupe manual transmission)
Old Apr 12, 2013 | 01:34 PM
adamj27's Avatar
I'm doubting you did your research. You can literally google "pop charger" and see. Does yours look like what the images show?
Yes - you have a pop charger
No - you dont.
Google "pop charger heat shield g35" - first result for me is a czp link to buy the heat shield. There you go.
Your drive shaft is not filled with oil. If its damaged, or if the transmission side is leaking then you'll have to look yourself or get a mechanic to look. Not much to be said over the internet without pics anyway.
If you want autozone part numbers, go to autozone and tell them what you need. Thats their entire job.
HFC just make it louder. imo. its not until you go with test pipes that you can get raspy sounds or anything dramatically different. even test pipes still have the typical vq sound.
Detailed Image
Aug 7, 2015 02:10 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
BlueBelleG35x
Jul 23, 2015 02:10 PM
