Creak Noise
Old Apr 17, 2013 | 10:58 AM
youloze's Avatar
After listening to the video, that sounds exactly like the sound I had. Turned out to be the metal rear brake pad guides that sit in the calipers. I greased them up and the noise went away for a while and came back. I later replaced the rear rotors, pads and guides and the noise has been gone ever since.
Old Apr 17, 2013 | 10:26 PM
sjsharky4's Avatar
What exactly are the brake guides? Are those the things the pads sit in? The thin metal piece that snaps on the back of the pad?
Old Apr 17, 2013 | 10:30 PM
youloze's Avatar
Yep, that's them
Old Apr 17, 2013 | 10:40 PM
sjsharky4's Avatar
Yep, that's them
Probably a dumb question, but can I get the guides at any auto parts store? Or should I go to the dealership? Do you remember how much the ran you?
Old Apr 17, 2013 | 10:48 PM
youloze's Avatar
I got them online with my pads and rotors. You can buy them through the dealership or online. Local auto parts stores wouldnt carry them.
Old Apr 18, 2013 | 12:10 AM
1V8ADAY's Avatar
That sounds like a bushing of some sort that has worn. The axle click is a deff click. You have a sway bar bushing, subframe bushing or something to that effect going on IMO.
Old Apr 18, 2013 | 11:37 AM
sjsharky4's Avatar
That was my initial thought. I'm going to really need to spend a good amount of time under the car to figure it out. I will let you know how it goes
Old Apr 27, 2013 | 09:54 PM
sjsharky4's Avatar
Alright guys so after jacking up the car I did not find anything. I shook my sway bar and moved it around, could find anything wrong. I also took off the wheels and greased all of the pins and pads in my caliper, still no improvement. I doubt I can live through another week of this. Any other ideas? Thanks a lot for the advice that has already been given!
Old Apr 30, 2013 | 11:32 AM
sjsharky4's Avatar
Bump, anyone know?
Old May 30, 2013 | 12:03 AM
sjsharky4's Avatar
I just replaced the swaybar endlinks, no luck. The noise is still the same. Any other ideas?
Old Jun 2, 2013 | 10:33 PM
sjsharky4's Avatar
Thoughts??? Im going insane!
Old Jun 5, 2013 | 09:39 PM
sjsharky4's Avatar
Bump
Old Jun 6, 2013 | 10:20 AM
youloze's Avatar
I would recommend actually getting new brake pad guides. I greased mine at first and it didn't really help. When I bought new rear rotors I decided to get the guides as well. I lubed them up and installed them and the noise was gone for good. They are cheap and easy to replace so it's worth a shot. If you do it lube the pins as well.
Old Jun 6, 2013 | 03:51 PM
sjsharky4's Avatar
Ok! Imma get them today at the dealership.. Let you know how it goes
Old Jun 6, 2013 | 03:52 PM
  #30
youloze's Avatar
Good luck!
