Need help with part (pulley)
Old Apr 27, 2013 | 01:35 PM
mobbdeep1122's Avatar
I replaced my drive belts and now on a cold start I get a loud squeal for the first minute or two and then goes away. After doing some searching on here, I've seen the pulley is the most common cause of this.
My question is, what exact part (part number) do I need to replace it? Any help is appreciated.
Forgot to mention I have an 03 Coupe
Old Apr 27, 2013 | 01:55 PM
cvipgo's Avatar
11925-AG30A and 11925-AL50A
Old Apr 27, 2013 | 03:16 PM
Thanks - either one will do?
Old Apr 27, 2013 | 03:23 PM
cvipgo's Avatar
these are two different ones 11925-AG30A -IDLER,COMPRESSOR,11925-AL50A Alternaltor , I would replace both.
Old Apr 27, 2013 | 03:59 PM
Gotcha - thanks again!
Old Apr 28, 2013 | 01:08 AM
leonardo_06G35's Avatar
Loud squeal that goes away is usually caused by improper tension on the belts, especially since it just started after you replaced the belts. Put more tension on the belts and it should go away. Though not a bad idea to replace both pulleys since they are cheap as preventative maintenance.
Old Apr 29, 2013 | 01:00 PM
GTX915's Avatar
Mobbdeep: I have the same problem man, let us know if the pulleys solves your issue please, thanks
redonblack35
Accessories
19
Feb 13, 2016 11:19 AM
EricF
Aug 28, 2015 08:27 AM
linedr89
Aug 17, 2015 05:11 PM
