Weird Door Lock Problem
Wondering if anybody had an issue where the door would lock but NOT unlock automatically?
I just had the actuator fix done on my G but for some reason it would only unlock the door but not lock. Not sure how to use the FSM to tackle this one... Does anybody know where the fuse would be for the door locks? I'm thinking this isn't the solution though because then why would it unlock?
Your actuator fix was proabably not installed correctly and if you used the aftermarket $5 fix the pin that goes into the lock mechanism is probably not seated. I would take the door panel off and check it again to make sure everything is in all the way. Also where the actual "actuator" is placed the long bar might be stuck going forward because it is not straight. If it is slightly bent it will not move both ways.
will091195
Jul 27, 2015 09:19 PM
