Coolant Fluid Issues Anyone?
Old Jun 14, 2013 | 08:48 PM
Unknown126's Avatar
Is it just my car or has anybody had issues with coolant consumption?
I drive my car daily and every 2-3 weeks I check the routine maintenance. Whenever I check the coolant fluid, I am almost below the "low" line. I have no fluid leaks anywhere in the car and the car barely has 37k miles.
Anybody had this issue with their g35 coupes before? Ive searched but couldnt find anything regarding this issue. Maybe its a normal thing for our cars? Maybe not?
Old Jun 14, 2013 | 08:52 PM
herrschaft's Avatar
Any smoke from the exhaust? If your absolutely sure there are no leaks, than you may have a bad head gasket.
Old Jun 14, 2013 | 08:56 PM
Unknown126's Avatar
I dont see any smoke from the exhaust. I was hoping it wouldnt be anything from the engine... But worth to get it checked... Thanks alot for the good info sir!
Old Jun 14, 2013 | 08:59 PM
rsingerG35's Avatar
Any coolant in the oil?
Old Jun 14, 2013 | 09:12 PM
Unknown126's Avatar
This might be a stupid question for you, but how the heck can I check for coolant in my oil??? lol. How is that possible?
Old Jun 14, 2013 | 09:24 PM
rsingerG35's Avatar
Take off the oil cap. If there is a milky type flim inside the cap, then theres coolant in there.
What year is your G?
Old Jun 14, 2013 | 09:48 PM
Unknown126's Avatar
Ohhhh ok.. well, there is no milky liquid in my oil.
I have an 06 g35 coupe 6MT with 37k miles.
Old Jun 14, 2013 | 09:55 PM
rsingerG35's Avatar
Best bet is a pressure test to check for leaks. If no leaks are found then testing your coolant for exhaust gases to rule out a HG.
Old Jun 14, 2013 | 11:15 PM
gary c's Avatar
Good news is you don't have coolant in your oil! (blown head gasket) Check your tailpipe for excessive moisture after it's been driven for a while, s/b dry. Moisture indicates head gasket issues. If you don't find anything have your system pressurized for leaks. I can smell coolant if I have a leak long before it shows up in my recovery, you should too.
Gary
Old Jun 14, 2013 | 11:49 PM
xXHotelCrazyXx's Avatar
Where in CA do you live? If you live in the valley, with the hotter temps they have been getting, you actually will lose some due to evaporation out of the reservoir.
Old Jun 17, 2013 | 09:59 AM
Unknown126's Avatar
Yeah, maybe I should try this.. Im gonna go take it to a mechanic this coming weekend when I get the chance. Thanks!
Old Jun 17, 2013 | 10:01 AM
Unknown126's Avatar
Gary
I dont think it could be a serious issue... (Hopefully). This car is still in good condition and I do the routine maintenance as it should be. And yeah, I can tell whenever I smell coolant because that happened with my old car and it has an obvious smell lol. Thanks!
Old Jun 17, 2013 | 10:05 AM
Unknown126's Avatar
I live in SD. I was thinking maybe it could be that issue, but its still not that hot around here in SD. But still that didnt happen with my previous car (2004 Acura TL).
All G'd Up
Aug 29, 2015 12:40 AM
NemesisGee
Aug 11, 2015 07:10 PM
saskicker32
Aug 11, 2015 02:12 PM
Phenomenon9
Aug 9, 2015 01:34 AM
joedaddy1
Jul 28, 2015 02:58 PM
