Weight Distribution of 05 G35 coupe
Old Feb 1, 2005 | 06:39 AM
L454's Avatar
Question Weight Distribution of 05 G35 coupe
On the infiniti website it says 53/47. On nissannews.com and in the brochure it says 54/46. Anybody have any idea which one is right?
Old Feb 1, 2005 | 09:44 AM
Q45tech's Avatar
But then all that changes with amount of gasoline and drivers weight and anything in trunk or different wheels tires. Not sure if 35-40 pounds divided by 2 front tires is significant.........1%. As drivers might be 100 pounds or 300.
Old Feb 1, 2005 | 10:14 AM
Sickone's Avatar
the coupe is 53/47 the sedan is 54/46
though that doesn't matter as much as what the balance is while in use, under accel it is near 50/50 - close to the same as you go into a corner.
The balance doesn't mean anything when static (standing still or cruising at a fixed speed. It is only when you apply a force (accel, cornering, braking, etc) that the balance/distribution matters
Old Feb 1, 2005 | 10:25 AM
yacoub's Avatar
Yeah. 53/47.
I took mine out in the last snow (just an inch or two of sleet & snow. I have Blizzak LM-22s btw) and it is wonderfully balanced. I took it to a big open parking lot and practiced controlling it. The LM-22s were money. I only slid or lost traction when I wanted to (ie, when I gave it extra throttle to break it loose) and it was so smooth and enjoyable to gently rotate around the lot.
Old Feb 1, 2005 | 12:14 PM
L454's Avatar
One percent is really nothing. It really wasn't all that important as more for my fyi. Supposedly the best for a rwd sports car is around 40/60 like a Ferrari. Thanks for the replys.
Old Feb 1, 2005 | 12:53 PM
avs007's Avatar
The weight distribution changed? I could've sworn my 04' was advertised as 52/48
Old Feb 1, 2005 | 07:29 PM
L454's Avatar
I believe even the Z has a 53/47 weight distribution.
Old Feb 1, 2005 | 11:47 PM
ChazM's Avatar
i thought its better to have closer to a 50/50, like the RX-8 i believe.
Old Feb 2, 2005 | 01:30 AM
L454's Avatar
Ferrari and most supercars actually have a bias to the rear wheels.
Ferrari F430 43/57
Lamborghini Gallardo 44/56
I also believe F1 cars have this bias, but I could be wrong. I am by no means an expert. From what I understand neutral handling is easier to drive while a rear axle bias can give you better performance but at a higher skill level. Somebody can jump and correct me at any time.
Old Feb 3, 2005 | 09:24 AM
Q45tech's Avatar
What is much more importantant [than static weight distribution] is the POLAR MOMENT of Inertia. How much weight [%] hangs in front/behind the center [of contact patch] of the front / rear wheels.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
mushu
Jul 15, 2015 03:55 PM
