Replace Ignition switch and key with a used one
Old Jul 14, 2013 | 09:42 AM
mrathell's Avatar
Hello everyone;
If I replace the ignition switch in my G35 Coupe 2005 with a used switch and key from a similar G35, would it immediately allow me to start my car or will it need to be programmed?
Thank you in advance.
Old Jul 14, 2013 | 11:41 AM
krazzyborri's Avatar
Pretty sure it has to be reprogrammed... The coded key is not just through the key cylinder, its also through the ECM (computer).
and at that point all the keys would have to be reprogrammed.
Old Jul 14, 2013 | 12:47 PM
mrathell's Avatar
So most likely to make that work, the ECM, key and key cylinder must be from the same car....and possibly the BCM?
Old Jul 14, 2013 | 01:16 PM
superchargedg's Avatar
yep
chinee
Jun 10, 2024 07:48 PM
.cakestar
Aug 4, 2015 09:05 PM
apintojr
Jul 23, 2015 10:52 AM
