Can changing from MT-90 to valvoline make it hard to shift?
Old Aug 19, 2013 | 08:55 PM
jwrape's Avatar
Originally Posted by wallofgrath
The metal shift plate under the shift boot is may not be aligned properly, so you physically can't put the car in reverse. Google search it. I had this problem, mechanic said he did everything right but I insisted he double check... I was right, easy fix.
That might be true because I did put the jack there before I realize there was nothing in that. Dumb mistake I know. I'll look at that tomorrow. You could be on to something there.
Old Aug 20, 2013 | 04:52 PM
jwrape's Avatar
Can't seem to find any issue except 1st and Reverse are really hard to get into. Reverse makes a awful noise
Old Aug 21, 2013 | 05:27 PM
jwrape's Avatar
I emailed the place I bought it from and they said they are sending me a new pressure plate. Still a ton of work to pull the trans again. Not looking forward to it.
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
NemesisGee
Aug 11, 2015 07:10 PM
