04 6MT feels heavy when accelerating
hey, hopefully someone can help me out. i just hit 90k and when I hit the gas pedal it feels like im pulling weight. I know its not normal, I have been driving it for a couple years now.
here is the kicker. If i give it 1/4th gas it drives normal. when i press any harder or floor it, it feel like the throttle response is delayed and i have no power.
Any advice would be appreciated.
Thank you.
Thank you.
I do regular maintenance.
thank you everyone who replied. does anyone have instructions on how to reset the ECU ??
Does the car sound any different in terms of exhaust note?
Your description of the symptoms reminds me of what people usually report when their Cat or Cat's are clogged.
No, the exhaust sounds the same. idk if its relevant but it also sound like the throw out bearing is rattling.
No the clutch feels fine. I did the 40 mph and pop 5th and it just kept accelerating. With RPMs normal.
You might want to try running a can of fuel injector cleaner through a tank of gas the next time you fill up.... although these things generally aren't miracle-workers. You said you have no Check Engine Light on right? What about other lights on the dash... such as SLIP/VDC or Tire Pressure warning? All of these being on at the same time can indicate a problem as well which could be putting it into limp mode (although I'm pretty sure the CEL comes on with them too).
If they are the original plugs and not some cheap aftermarket replacements, they aren't overdue. These cars come with 100K mile iridium plugs rather than your typical 30K ones of yesteryear.
I checked my maintenance guide & first plug replacement is 105,000 mile 84 month checkup, so I stand corrected there.
