ECU coolant temp sensor location?
Old Oct 23, 2013 | 06:19 PM
luis_fx35's Avatar
Hi everyone, since the G and the FX share the same engine, Does anyone know where is the ECU coolant temp sensor?
The sensor is no longer reading the increasing engine temp and so the ECU is assuming the car is still cold and is supplying air/fuel in a much more rich mixture than it would on a hot engine. When I'm driving is ok no problem but once I stop or at idle I feel a shake and hear a poping noise from the muffler. I've been told that once I replace this sensor my problem would be fixed. I already checked the O2 sensor and the MAF, so this is my last chance to get this fixed.
Thanks,
P.D. is there another sensor for the temp gauge and a different one for the ECU? the sensor I bought is this one, is this the right one? Check the link
http://www.stockwiseauto.com/product...source/thefind
Old Oct 23, 2013 | 10:34 PM
luis_fx35's Avatar
nobody?
Old Oct 24, 2013 | 01:44 AM
xXHotelCrazyXx's Avatar
Old Oct 24, 2013 | 07:49 AM
Cux350z's Avatar
its in the rear coolant hardpipe
Old Oct 24, 2013 | 02:14 PM
luis_fx35's Avatar
is there a how to? there is not much space in there? Do I have to drain all the coolant? would I get a CEL after I replace it? I don't have a CEL now. Is it ok to use an aftermarket sensor that I got from Oreilly or should i buy OEM? is there an FSM for this?
Old Oct 24, 2013 | 04:13 PM
Mustang5L5's Avatar
Page 30, item #4 in the diagram
http://www.nicoclub.com/FSM/G35/Seda...5_Sedan/co.pdf
I haven't changed a sensor on a G35, but on other cars, you typically don't need to drain the coolant. It unscrews with a wrench, and you screw the new one in. Seems as if there is a gasket with the sensor that should be replaced as well.
A faulty sensor should through a CEL however. You should be able to unplug the sensor, and measure resistance across the leads.
http://www.nicoclub.com/FSM/G35/Seda...5_Sedan/ec.pdf
Page 229 details testing of the ECT and known values you should get with a digital multimeter.
Old Jul 16, 2015 | 02:48 PM
Shivaji's Avatar
Was issue fixed when you replace the sensor ?
I got same issue in my 2003 g35 Sedan. My machanic don't know where is the problem. Did u replace the sensor ? Was it success ?
redonblack35
Accessories
19
Feb 13, 2016 11:19 AM
djreinx
Engine - Electrical
Dec 10, 2015 01:48 AM
sofa king
19 Inch
Aug 9, 2015 04:10 PM
andrewvk
Interior
Aug 6, 2015 05:51 PM
EliteG
Engine - Electrical
Aug 5, 2015 07:50 PM
