Belts squealing after being replaced and on idle overheating
I recently had my timing and serptine belt replaced. Ever seen they have been replaced the squeal on start up and when I'm idling at a red light or traffic some times when I start to engage driving again the temperature rises almost overheating. Is the overheating have anything to do with the belts squealing? I have taken it in 3 times and they say the belts are fine. I have no coolant loss or any overheating problems other then the times the belts squeal. Is this even possible? Any guidance would be greatly appreciated as I am lost.
Infiniti g35 coupe 2003
83,000 miles
Manual transmission
83,000 miles
Manual transmission
I sounds like your newly installed serpentine belt is not tightened correctly. That belt also drives the water pump which is necessary for cooling. Take it back to shop that did the installation.
The water pump is chain driven, has nothing to do with the belts. Overheating problem should not be related to belts. Belt noise most likely caused by contaminated belts (coolant on belts from a leak?) or incorrect tension.
i recently had my timing and serptine belt replaced. Ever seen they have been replaced the squeal on start up and when i'm idling at a red light or traffic some times when i start to engage driving again the temperature rises almost overheating. Is the overheating have anything to do with the belts squealing? I have taken it in 3 times and they say the belts are fine. I have no coolant loss or any overheating problems other then the times the belts squeal. Is this even possible? Any guidance would be greatly appreciated as i am lost.
83,000 miles
manual transmission
83,000 miles
manual transmission
Rehman2009
Jul 27, 2015 03:23 AM
