vdc off and slip light on
Old Nov 4, 2013 | 11:52 PM
DouG35's Avatar
i have already searched on this and mine different cant find anything on it. I hace an 04 coupe g35 my vdc off and slip stay on never shut off break light dose not come on no code comes on for g sensor so i really have no clue what it is. Ive delt with it for about 9 months and i live in chicago so snow is probably coming anyday now. So if anyone can think of anything lmk please oh and my abs light is off works fine.
Old Nov 5, 2013 | 12:59 PM
DouG35's Avatar
Bump
Old Nov 5, 2013 | 01:18 PM
mjwalter80's Avatar
You'd probably get some responses if you could write with punctuation and in complete sentences. I have no idea what the hell you are asking.
Old Nov 5, 2013 | 01:21 PM
DouG35's Avatar
I knew that was coming.
Old Nov 5, 2013 | 02:02 PM
That's G's Avatar
Check your brake fluid levels. Some have had problems with their dash lighting up when it's low.
Old Nov 5, 2013 | 02:04 PM
Peoria35sedan's Avatar
you need to pull the codes from the BCM. If you know someone with cipher & a cable they can get them for you or take it to a shop.
Old Nov 5, 2013 | 02:15 PM
Ejgold55's Avatar
OP - lasdlqhdlahds q;wjdhqw qjlhwd;lqjwhdq qjwhdqljwhdlqjwh;doeoie ppppp and and oil. that will fix everything.
Old Nov 5, 2013 | 03:30 PM
kay.cakess's Avatar
HAHAHA
anyways, like one of the other members already mentioned try checking your brake fluid. Happened to me about 2 months ago. Filled it up and it went away.
Old Nov 5, 2013 | 05:06 PM
DouG35's Avatar
Not the break fluid.
Old Nov 5, 2013 | 05:20 PM
DouG35's Avatar
Will a snap on scanner work for that. I have no codes on my dash
Old Nov 5, 2013 | 05:34 PM
vashawn's Avatar
This just happened to me on sunday when i started my car, but with the all 3 lights. brake, vdc and slip.
Brake light turned off when i made a turn and the other 2 turned off 5 hrs later.
I then added brake fluid on monday which the level was on min.
The only code i had which was from a month ago was the P0430 which im guessing i have to change my cats.
I hope this **** doesnt return
I live in NY and winter is upon us!!
Old Nov 5, 2013 | 06:14 PM
DouG35's Avatar
My vdc and slip light have been on for nine months. Never had my break light come on. NY well then you know how it's abou the same for us.
Old Nov 12, 2013 | 11:31 AM
driftsucky's Avatar
VDC/Slip lights don't have anything to do with the brake light coming on. Not sure why everyone keeps mentioning it. While they are all dealing traction issues, they are independent of each other.
If your VDC/Slip light is on, that could be any number of things. It could be simply a sensor OR it could be a module OR it could be a fuse OR it could be tire pressure/wheels (i.e aftermarket wheels, under/overinflated tires although that's rare, bad wheel sensors). So, what I would do is ensure everything is in stock form FIRST. If that's in good working order, I would check fuses. Men spoke of you being able to pull a grey fuse in order to disable the VDC/SLIP function for happy fun time drifting. So, I would find that fuse and make sure it's good to go.
IF you do all that and everything checks out, your only other option is to take it in to a shop. The VDC/SLIP won't throw any codes that I'm aware of. In NY, we can't get an inspection if any codes are present in the ECM and my VDC/slip lights have been on ALMOST since I bought the car. It works because I disabled it for happy fun time drifting.
With snow tires and caution, you don't need VDC. I don't use either the few times I may drive my car in that white powder, but I've had RWD in the winter for the better part of my adult hood and I prefer not to have any kind of traction control.
Old Nov 12, 2013 | 11:44 PM
DouG35's Avatar
Thank you and everything on the car is stock beiside 2" drop and exhaust. I was looking at the wire daigram and seen that the g has a steering sensor. My car ailment is off so do you think that could have something to with it cause if the ecu or g sensor is reading that it is not zeroed out. It could cause it to throw the vdc/slip.
Old Nov 22, 2013 | 09:45 AM
infinitidude's Avatar
Sounds like the steering angle sensor needs to be reset. If the car was aligned once it was lowered, the steering angle sensor could have gotten thrown out of sync
