Coupe Interior 3rd Brake light doesn't work
Old Nov 14, 2013 | 11:59 PM
Jyounya's Avatar
Ivory Pearl G35 Coupe
Does anyone have a fix for this?
Old Nov 15, 2013 | 01:12 AM
Jyounya's Avatar
Went from wing to wingless. Bought an interior 3rd brake light and it doesn't work. Thought there might be a quick easy fix for this.
Old Nov 15, 2013 | 09:22 AM
Urbanengineer's Avatar
Yeah, test your light to make sure its not the problem. How? Maybe it runs on 12V DC.
Old Nov 15, 2013 | 09:37 AM
Jyounya's Avatar
Thanks for the reply,
Well I bought an OEM G35C interior 3rd brake light of ebay. Before installing it, I plugged it in and hit the brakes and nothing, however the trunk lights work, and the two main brake lights work. I haven't tested any type of wiring in over 14 years, nor do I have a multimeter or test light. I bought it knowing it didn't work but figure I could fix it with help from fellows at G35driver.com.
Old Nov 22, 2013 | 09:31 AM
infinitidude's Avatar
On the 3rd brake light, the harness plug-in has 2 wires one of which is pink with a blue stripe(this wire color is used for pretty much all illumination on infiniti vehicles) back probe with a test light and hit the brake pedal. If it lights the test light up then you know the wiring is good on the power side. If it doesnt light up you can also check under all of the paneling next to the spare tire,there is a brown looking connector which is actually a power distribution block. Just had a coupe the other day and all 3 wires at this block were broken plain as day. Hope this helps
Old Nov 22, 2013 | 10:00 AM
Jyounya's Avatar
Thanks for the reply. I'm convinced it's the actual LED assembly giving me the issue. I have two trunks...the orginal trunk has the OEM spoiler with 3rd brake light, which I put back on last Wednesday and the new wingless trunk, in which I had to buy a used interior 3rd brake light that doesn't work. The brake light on the spoiler still works when plugged in but when I plug the other 3rd brake light, it will not illuminate when hit the brake pedal. I feel like I need to buy a multimeter and start testing the LEDs.
Old Nov 22, 2013 | 10:43 AM
There is no need, the harness for the spoiler and harness for 3rd light are on the same fuse, if you call the dealer unfortunately the 3rd brake light for the coupe comes in the colored housing to match the interior. If it was a sedan, you could get the led set up by itself
mike730
Jan 12, 2018 04:25 PM
R350k5
Oct 1, 2015 08:41 PM
myaso
Lighting
Jul 22, 2015 10:34 PM
Lsantana757
Jul 20, 2015 09:08 AM
