Slight Loss in Power Steering and faint rubber smell
I'm a very low mileage driver. Have 44K on my '06 coupe.
If anyone is experiencing slight loss in power with a faint rubber smell this means your belt needs tightening (or replacing). I thought it might be the PS pump but was noticing the thermostat and heater running coolant cycles very frequently (no overheating) which meant the water pump might be under performing...all symptoms led me to the belt.
Surprisingly enough, the A/C belt was the one that had cracking...the P/S belt was just fine. Slapped on two new ones ($42) and steering was back to normal.
Dealer wanted $285 for 2 belts installed.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
FS[SoEast]: 2006 DG Coupe Part Out - mrev2, projectors, etc
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
ScraggleRock
Aug 11, 2015 10:16 PM
