Auto shift knob switch to GTR
Old Dec 19, 2013 | 07:40 PM
Eric@TCGMiami's Avatar
750 for a shift **** woah
Old Dec 19, 2013 | 07:52 PM
http://www.conceptzperformance.com/C...3466.249.73.37
280.53
Old Dec 19, 2013 | 07:53 PM
willmkent's Avatar
yea, man. Too expensive for a ****. Here is my thing, I really don't like the 04 Auto shifter.... any way to convert to the 06 shifter with the boot and everything???? It looks a lot cleaner
Old Dec 19, 2013 | 07:59 PM
Frankieg35's Avatar
Yes but its a custom job..
Old Dec 19, 2013 | 09:34 PM
willmkent's Avatar
ahh, why can't this be easy lol. anyone have any other alternatives for me???? pics would be sweet too
Old Dec 20, 2013 | 12:40 AM
Irrelevant's Avatar
If one wanted, they could shorten the height by an inch or more pretty easily, if I recall correctly.
This may or may not be of interest, but you asked for ideas...
Old Dec 20, 2013 | 12:51 AM
saywat?'s Avatar
Looks like they jus raised the foreskin. Sorry to say but that is waaay too poser
Old Dec 20, 2013 | 09:30 AM
willmkent's Avatar
Not a bad idea, and I don't want to be a manual, I just want to clean up the fugly stock auto shifter
Old Dec 20, 2013 | 09:32 AM
WhosUrBuddiee's Avatar
Poser? The 6MT is no better than 5AT, both are slow as sh*t. It is merely a personal choice of style.
Old Dec 20, 2013 | 09:47 AM
gary c's Avatar
I didn't cut the shifter shaft on mine just the plastic actuator in the center which lowers the **** 1/2". Better choices for a AT **** is the KJ burnt Titanium **** combined with a NiftyShifty boot. (check my garage photos) I believe Sean aka SXEXCX is still selling both on our Marketplace. This shifter puts a smile on my face every time I sit behind the wheel...Gary
Old Dec 20, 2013 | 10:22 AM
willmkent's Avatar
doesn't look bad man! I like the idea, is there anyway to tighten up the leather boot, or must it be that loose to compensate for the movement of the shifter??
Old Feb 25, 2014 | 07:56 PM
willmkent's Avatar
Alright guys! I found one and bought it! Check out my unboxing pics
Now, I went to test fit the **** and so far this is what I came up with:
I removed the OEM 04 shift ****, found that the plastic piece may be too thick to fit into the hole in the GTR ****, so I removed the plastic piece and put the **** on, The GTR **** went over the shifter and i was able to clip it in, HOWEVER, without the plastic piece, obviously the shifter top would not release the shifter to move, AND there was a little play associate with the **** it moved around a little bit)
Can anyone who has changed there **** to anything, provide a little insight on how to set this up. I am willing to cut the shifter stem down and shave lines into the stem for the clip to sit properly, I just want to make sure that I don't EFF up anything because it isn't "undoable" i would need an entire shifter assembly if I do. However I am very excited to get this done, as it cleans up with the shifter column quite a bit
SEE BELOW, This was done on a 370z
Old Feb 25, 2014 | 08:16 PM
ChinkyChoy's Avatar
was done on a G37
too much money for me personally tho
Old Feb 25, 2014 | 08:18 PM
saywat?'s Avatar
looks nice on the z. so long u can keep it short like the gtr itll look nice.
Old Feb 25, 2014 | 08:21 PM
  #30
willmkent's Avatar
Thanks man! I didn't see that it was done on the G37, the **** is the only expensive part and I bought it used from the GTR forum so it wasn't too bad. Any idea on where I should look to try to get this to work on the G35?
