Aftermarket bumper fog light help!
Old Mar 11, 2014 | 10:09 PM
saywat?'s Avatar
im rice I daily my fogs at night without the headlights.. looks cool
Old Mar 11, 2014 | 10:10 PM
itztwinki3's Avatar
without oem fogs on
with oem fogs on (doesn't look bad after all)
Old Mar 11, 2014 | 10:14 PM
itztwinki3's Avatar
pretty much lol
Old Mar 11, 2014 | 10:16 PM
itztwinki3's Avatar
truthfully it doesn't seem that bad. some people would think you are driving with high beams on if you had both the oem low beam and fogs on
Old Mar 11, 2014 | 10:17 PM
itztwinki3's Avatar
but how do you run the fogs on without the headlights? I tried on my car and no luck. LOL wanted to give it a try.
Old Mar 11, 2014 | 10:19 PM
saywat?'s Avatar
foglight wiring harness from ebay $15 wired to the oem fogs. so I have it on its own switch like ur aftermarket fogs
Old Mar 11, 2014 | 10:20 PM
itztwinki3's Avatar
do you have a link?
Old Mar 11, 2014 | 10:21 PM
saywat?'s Avatar
jus search "foglight wiring harness " on ebay. theres only a few sellers
Old Mar 11, 2014 | 10:24 PM
itztwinki3's Avatar
oh one of those. i have an extra one that the shipper sent me. ima install them when i install hid to the oem and the aftermarket. just waiting for them to come in already lol.
Old Mar 11, 2014 | 10:35 PM
itztwinki3's Avatar
They look very nice, but not to be picky and all... but I want to see it with ALL the lights on too....
what do you think now?
Old Mar 11, 2014 | 10:42 PM
Urbanengineer's Avatar
Thanks for the pictures! It looks great and if you could share your wiring diagrams, aka what you tapped into that would be great.
As for running the fog lights all day, well it can crack your housing as they produce a lot of heat, so be warned. It would be illegal to run only the fogs at night while driving, you can't see more then 25'!?!
Old Mar 11, 2014 | 10:51 PM
itztwinki3's Avatar
this is what I pretty much use for reference. due to the fact everything i bought from amazon came with a harness, relay, and wires. even extra wires if not long enough.
everything is already plug and play. you just got to attach the grounds to a bolt or screw, plug into battery, and the switch power wire, tap it with the IGN fuse inside the car.
Old Mar 12, 2014 | 04:49 AM
saywat?'s Avatar
Bc the fogs are up high in,the headlight housing the output is very useful n like driving lights unlike traditional low fogs on the bumper. The output usually sucks n jus for looks imo
Old Mar 12, 2014 | 07:47 AM
Thank you. You got us that much quicker then I expected to see it!
It looks pretty easy to wire up, just don't want to cut into the bumper so I'd probably fabricate something myself!
Old Mar 12, 2014 | 09:02 AM
  #30
Texasscout's Avatar
I used the same set up in my pick up for my aircraft landing lights. However, I tied the wire from the ignition to the high beam feed, that way the driving lights only came on when the high beams were on.
