SunRoof problem HELP
Old Mar 5, 2014 | 09:47 PM
Bwoyalex's Avatar
I am a fairly new driver of a 03 coupe, I got it back in late last december. My sunroof is giving me problems. For one, when it closes it just reopens the other way. it does not close automatically, it closes manually. I have to press the opposite button to make it balanced on the roof, what can i do to stop that? Also when i try to open it fully, it slides back half way and stops. Is there anything i can do to fix this problem?
Old Mar 5, 2014 | 11:55 PM
gary c's Avatar
Welcome to G35 Driver!
Two or three times a year I clean my sunroof railings with carb spray then I apply a bead of silicone spray. It always works just like new! Maybe, your railings are so full of crud the sunroof doesn't work correctly...cleaning is a start and maybe your answer.
Gary
Old Mar 6, 2014 | 12:05 AM
Bwoyalex's Avatar
Thank you!! I will try this out tomorrow
Old Mar 6, 2014 | 12:28 AM
iloverice's Avatar
My sunroof would open but it would take me about 10-15 mins to close. It would close bout 1/8 of length then open back up. It will keep doing that till it feels like closing
Old Apr 26, 2014 | 03:23 PM
candyvp's Avatar
I have had this problem before. The sun roof is out of sinc sometimes you have to reset it. i believe in the owners manual it will tell you how to correct it. if you can't find the info in the book let me know i will try and find it.
Old Apr 26, 2014 | 03:39 PM
Bwoyalex's Avatar
Okay thank you. I will go check it out right now
Danielek
Oct 7, 2015 09:59 AM
wuzz-upp
Oct 3, 2015 04:21 PM
mattdg35
Sep 14, 2015 11:28 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
