oil on spark plugs
Old Apr 27, 2014 | 06:08 PM
bamster's Avatar
oil on spark plugs
I have a 2005 G35 sport coupe with 115,000 miles on it. Just changed the plugs and noticed oil on the 2 plugs closest to the firewall . One on the drivers side and 1 on the passenger side. I had noticed an oil smell for a while and couldn't figure out what it was. Now I know. The car is running fine but I seem to be getting worse gas mileage than before. Is this because of the oil? If I continue to drive the car the way it is will I damage anything engine wise and just put up with the smell and worse gas mileage or should I have this taken care of right away. What am I looking at price wise and what exactly will I have to have done?
Old Apr 27, 2014 | 06:27 PM
Stillen06coupe's Avatar
Is it on the spark side of the plug, or the side where the boot plugs into it? If it's on the boot side, no worries. Only new valve covers will fix it(built in gaskets). If it's on the spark side, then you have issues somewhere(valve seal)
Old Apr 27, 2014 | 06:39 PM
Urbanengineer's Avatar
I think you have those backwards, wording is confusing.
Old Apr 27, 2014 | 07:23 PM
It's right. Lol. If it's on the part that actually sparks, it's an internal problem. If it's on the ceramic side, it's the gasket
Old Apr 28, 2014 | 02:11 PM
bamster's Avatar
I believe it's on the spark side, the side that's threaded. That's where I saw the oil. The electrode side. What will happen if I continue to drive it this way? What kind of work will I need to have done to fix the problem?
Old Apr 28, 2014 | 04:10 PM
Get a compression test done. If that checks out, it's not a piston ring. My guess after that would be a valve stem seal or bent valve. Is there a decent amount of noise in the valvetrain? If so, bent valve, if not, seal. Not very expensive to fix. Piston ring, expensive to fix
Old May 6, 2014 | 06:47 PM
slim17265's Avatar
what weight oil are you using? many here with high mileage still very light oil.. I would try 10W40 synthetic..( this does not emit blue smoke like the dinosaur stuff)
Vqalexisz
Oct 14, 2015 12:48 AM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
TNRocker
Sep 21, 2015 08:36 AM
johnadlertech
Engine - Complete Motors
Sep 6, 2015 12:45 PM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
