car showing completely wrong temperature
Old May 10, 2014 | 03:04 PM
usman85's Avatar
My g35 showing outside temperature of -17F,while the real temp is 70F. Cannot turn the air conditioner. did any body else had same problem.
Old May 10, 2014 | 04:37 PM
MicntaeG35's Avatar
Mine did this the other day and it's the time I've noticed it. It showed it was 65 when really it was well over 80.
Old May 10, 2014 | 05:29 PM
JKL1031's Avatar
what u gon have tuh do wez pop that grille off like dezz, unmount and unplug that lil sensor sitting behind dare,,looks like a plug and its got a nipple on the end of it. Take i tout and replace it,,BAM just like that.
Old May 10, 2014 | 06:46 PM
Urbanengineer's Avatar
:Postpics:
Old May 10, 2014 | 07:16 PM
JKL1031's Avatar
i cant find a picture of its locaation, but its on a bracket and looks like this
Old May 11, 2014 | 01:06 PM
usman85's Avatar
Thanks. I have ordered a new sensor and will change it. the sensor is called Ambient Temperature Sensor.
Old May 11, 2014 | 05:12 PM
JKL1031's Avatar
hai hai..
Old May 14, 2014 | 04:24 PM
usman85's Avatar
Changed the Outside ambient temperature sensor problem still exists. the car is showing -22F temp while its 65F.
Summer is starting and no air conditioner
Attached Thumbnails car showing completely wrong temperature-20140514_154323.jpg   car showing completely wrong temperature-20140514_154646.jpg
Old May 14, 2014 | 05:24 PM
JKL1031's Avatar
Really? I have the same problem xcept mines shows too high sometimes. that's weird. Do you recall seeing another one in the middle of the grille area?
Old May 14, 2014 | 05:40 PM
usman85's Avatar
There was another switch on the middle infront of radiator. It was attached with the metal plate infront of it and two bolt on screws. Not sure what that was.
Old May 14, 2014 | 06:01 PM
Shawno72's Avatar
Maybe turn off the auto air to manual?
Old May 14, 2014 | 09:05 PM
JKL1031's Avatar
Try replacing the one in the middle. you may have one for nav, and another for HVAC. I believe the one on my non nav was in the middle.
Old May 15, 2014 | 04:51 AM
partyman66's Avatar
You can't turn the A/C on, really? Hmm... i never knew they tied the AC to the outside temp. Usually most car manufacturers want your A/C to turn on sometimes, such as when you use the front window defogger, because it keeps the A/C moving parts lubed up and free spinning during those winter months where you typically wouldn't ever use your A/C, plus you defog better when the air is first cooled and then blown on the windows to help pull moisture out of the air.
Old May 15, 2014 | 12:21 PM
Mustang5L5's Avatar
Since you didn't post year (and many don't do this when asking for specific help) i'll provide both FSM's
There's a self-test procedure detailed at the end of the FSM to help troubleshoot it. This can get you started
03-04
http://www.nicoclub.com/FSM/G35/Coupe/2004/atc.pdf
05-07
http://www.nicoclub.com/FSM/G35/Coup..._Coupe/atc.pdf
Old May 15, 2014 | 01:47 PM
usman85's Avatar
Thanks Mustang5L5. I will go through this. The car is 2006 g35 coupe.
Meanwhile i checked the sensor on the middle of radiator. Not sure what it is for and cant find it online either. It has foam padding on the flat side. You can also see the ambient sensor that i replaced earlier.
Attached Thumbnails car showing completely wrong temperature-forumrunner_20140515_134646.jpg   car showing completely wrong temperature-forumrunner_20140515_134656.jpg
