car showing completely wrong temperature
Old May 15, 2014 | 04:34 PM
JKL1031's Avatar
Wwooaaahh that's the crash zone sensor!! *runn*
I'm not sure what to do next.
Old May 15, 2014 | 08:39 PM
Mustang5L5's Avatar
Yup, that's a crash zone sensor. Put that back.
Old May 15, 2014 | 11:21 PM
usman85's Avatar
Lol. Yeah i realized that earlier. Air bags are working.
Well i did went over the troubleshooting described on pdf attached by Mistang5L5. On page 101 and have to remove the center console in car to get to 20 pin switch for ohm meter. Then i saw that temperature started to fluctuate. Some times it will show correct temp and then started to drop down. It will turn a/c on when temp is correct and as soon the temp reading drop below freezing a/c will stop. This is getting annoying. Had to go to dealer now.
Old Jun 12, 2016 | 06:12 PM
matt0323's Avatar
This happened to me recently. Replaced the ambient temperature sensor and still reading -30C. Forget the stealerships. I figured it out myself for free.
Old Aug 8, 2016 | 10:44 AM
Andriea's Avatar
Ambient sensor and AC compressor
Hi, my AC compressor won't come on because my ambient temp is reading
--- icy so all I'm getting is hot air. I replaced the ambient sensor and that didn't fix it. I went to my small town mechanic (nearest dealership is 2 hrs away) and he tested the sensor wires and there's no power... So where do I go from here.. Test the AC amp or the AC relay power supply?
Where does positive voltage come from?
My boys come home from their dads next week and it's 105* degrees here, I need to fix it ASAP
Old Aug 8, 2016 | 12:00 PM
matt0323's Avatar
It is most likely one of the wires from the ambient harness snapped due to age. This was what happened to mine. Resoldered the broken wire and now it is reading the temperature outside correctly. Hope this helps
Old Aug 8, 2016 | 12:09 PM
Andriea's Avatar
Thanks for the quick response! I don't see anywhere that the wire is broken
Old May 11, 2022 | 08:41 PM
Kimo54's Avatar
G35x
That's my circumstance also.
Changed the Outside ambient temperature sensor problem still exists. the car is showing -22F temp while its 65F.
Summer is starting and no air conditioner
changed ambient temperature sensor still reading -22
arora_g35
Apr 16, 2026 02:52 PM
shavedcrx
20 Inch
Aug 7, 2015 04:14 AM
ClwMike
Jul 23, 2015 12:55 PM
justgotg35
Jul 19, 2015 12:33 PM
