G35 2004 Coupe, Window switch doesnt work
Old May 16, 2014 | 11:36 AM
M-ke's Avatar
Had a problem with my windows where it went all the way up and back down 1/3, so i performed the reset on driver side which works perfectly however the passenger side window wont go up or down with switches on either side, so to test the motor i stepped outside the car and used me key and held it to open and close both windows at same time, both windows worked, the one i performed reset on was still good the passenger still did the 1/3, my main problem is i cant perform a reset on other side bc i cant open or close with switches. please help!
Old May 21, 2014 | 05:42 PM
Zach W.'s Avatar
Had the same issue
I was having the same issue about a month ago. My passenger window randomly stopped working. The problem? The window lock button was pushed. I felt so stupid but I guess I some how overlooked the button! Make sure your button isn't pushed.
Old May 21, 2014 | 08:20 PM
M-ke's Avatar
Wow
I ended up figuring it out myself same day.. And it was exactly what you said, thank you! I thought I was only one who does that same mistake on more than one occasion
arora_g35
Apr 16, 2026 02:52 PM
vstypicals
Jul 20, 2015 10:55 PM
igking
Jul 19, 2015 01:12 AM
attarday
Jul 15, 2015 04:03 PM
