2004 G35 NEED HELP!!!! Starting problems
Old Jun 5, 2014 | 06:18 AM
lilmadmike's Avatar
Exclamation 2004 G35 NEED HELP!!!! Starting problems
hey guys,
i was driving yesterday and my car suddenly just died on me,
i tried to start up again but it doesnt wanna fire up, the engine will turn over but it wont start...
has anyone had this problem before?
can someone please help!
michael
Old Jun 5, 2014 | 11:01 AM
Blue Dream's Avatar
I drove ttrank's car solo
Sounds like a bad camshaft position sensor or crank sensor. Do you have the SES light on?
Old Jun 10, 2014 | 08:33 AM
lilmadmike's Avatar
no light has come on, how else would i be able to tell?
i took to the mechanics... big waste of time,
charged me 150 for diagnostic, then go to tell me that my ecu cant be found with their scanners and want me to send my ecu off for another $350 to tell me if its ok... plus any extra charges on top to repair.
they said maybe my immobilizer, and when i tried to start all dash lights are on and immobilizer light on as well.
Old Jun 10, 2014 | 11:33 AM
guitarrocker98's Avatar
I doubt its your immobilizer… I would go with Crank or Cam shaft position sensor. Though the lights are not coming on, I would still think a light would come on though. Sounds like the tech that touched the car is a moron… OR had a non Japanese scanner haha.
Old Jun 11, 2014 | 09:25 AM
Jonlex99's Avatar
Is the red LED light for the security system on while trying to start the car?
Old Jun 11, 2014 | 09:28 AM
Jonlex99's Avatar
From my understanding as soon as you insert the key into the switch the security light should go out.
Old Jun 12, 2014 | 11:29 PM
Mr.GEE's Avatar
20 Year Member
Check your fuses
Old Jun 14, 2014 | 08:58 PM
foreverdr1ft's Avatar
I had a very similar problem. "Blue Dream" has the right answer for the most part. Mine is also a 2004. My engine would do the same thing and/or had a hard time starting up and took multiple cranks to get it running. The problem began around 75k mlg. Although this is probably not mileage related, just giving you a point of reference.
Remedy for my starting problem- clean out the throttle plate with throttle body cleaner. There should be a DIY in this forum I believe.. Try this first because it's cheaper to do than changing out the CPS. If the cleaning does not work then change out that sensor. GL man!
Old Jul 23, 2014 | 09:20 PM
lilmadmike's Avatar
hey all!
after months ive finally got my baby back on the road!!!!!
it was just like i thought, for some reason my ECU decided to start playing up and was not able to pass the anti theft system. bought a second hand ECU and had it reconfigured to my car. now she runs fine
thank for all you help guys!!!!
Old Dec 23, 2015 | 03:28 PM
Vqalexisz's Avatar
Originally Posted by lilmadmike
hey all!
Hey where did you get your second ecu and did all numbers match ?
chinee
Jun 10, 2024 07:48 PM
vmcarbuyer
Oct 12, 2019 12:42 PM
brycealbr
Aug 11, 2015 11:47 AM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
