Head light question
Old Jun 7, 2014 | 01:13 PM
chinjesse's Avatar
Head light question
I am not sure if this is the right spot to post this but if not please move the thread.
I have a 2004 G35 coupe the problem is that my driver side headlight went out so I thought it was the bulb I tried replacing the bulb but nothing happens, what I did was put the HID bulb onto the connector thing "Where the picture of a lighting bolt is" I tried turning my head lights on and the bulb doesn't light up so from my mind I am thinking that my ballast has now died?
Because when I put the bulb on the passenger side connector thing and turn the head light on the bulb lights up
so what could be the problem? if one side works the other side don't
OR even better if you live in St.Petersburg FL and would like to stop by let me know!
Old Jun 7, 2014 | 02:07 PM
WhosUrBuddiee's Avatar
Go to harbor frieght, amazon, or homedepot and buy a digital multimeter.
Step 1. Test the connection going into the ballast, you should be getting 10.5-12vdc. If it is 0vdc, then you probably blew a fuse.
Step 2. Test the connection coming out of the ballast, you should be getting about 85vac. If it is 85vac, then your bulb is bad. If it is 0vac, then your ballast is bad.
Old Jun 7, 2014 | 03:27 PM
chinjesse's Avatar
I went out my way to go buy a whole new ballast hopefully this fixes the problem
Old Jun 7, 2014 | 04:01 PM
It would have been cheaper to buy a multimeter and you would have known for sure.
Or you could have just swapped the ballast from the working headlight to test.
Old Jun 8, 2014 | 01:15 PM
chinjesse's Avatar
True, but by the time I got your message I already went to go buy the ballast and turns out I got the wrong one lol I bought the aftermarket one that doesn't fit for our car -___-
Btw I was wondering for our head lights is the driver and passenger side connected with 1 fuse or are they separate fuses? because I want to check my fuses but idk where the fuse is located
mike730
Jan 12, 2018 04:25 PM
Fireman07603
Aug 9, 2015 06:00 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
VANST3R
Lights
Jul 27, 2015 08:20 PM
