G35 drive and a/c belt
Old Jul 8, 2014 | 10:43 PM
Peruanito0's Avatar
Hey guys im new at this page .. Prob there is a post with this info but if not then i just need the size of drive belt and ac belt how many ribs since in autozone cant give me the right size if anyone know .. Share it plz i will apreciate it thank you.
Old Jul 9, 2014 | 03:09 AM
partyman66's Avatar
Look at the belts that are on there now. If they aren't like 10 years old and faded/worn, you should be able to just read the numbers off of them and get the equivalent version stocked at your local Auto Zone or other auto parts store.
I believe all the G's use a 6-rib belt though. The length depends on what year you have... probably the same belt from 03-06 and maybe a different one henceforth. You'd need to give us more info about your car.
If you are just replacing factory belts though on an 03-06 G, you should remove the extra idler pulley on the front of the car and replace it with a 1" shorter than stock belt. It's a sweet "free"mod basically. All you have to do is either buy the small aluminum washer/spacer from Nissan, or order the kit from Z1 Motorsports (which comes with both a factory Nissan shorter-version belt as well as the spacer), remove the idler pulley assembly and replace it with the spacer and then install the new/smaller belt. The idler pulley delete saves you about 2 pounds of rotational mass on the engine and you'll never have to worry about that idler pulley wearing out and snapping your serpentine belt.
Old Jul 10, 2014 | 10:39 PM
Peruanito0's Avatar
Well its coupe 2003 with 120k miles not sure if they ever changed it .. But the way i found it i doubt they ever did so havent check it yet.. But i will do that thank you so much!!
champppy
Mar 31, 2020 12:25 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
brian_z
Jul 20, 2015 01:30 AM
