Plug gap after adjusted AFR ?
Old Sep 16, 2014 | 11:54 AM
maxxcool's Avatar
Need some input. as we know the 2003-2006,early-7 model ecus run lean. Partially from the Plenum starving the 1st two cylinders and throwing off the overall emissions average and the very conservative AFR tune from the factory.
I am about to get the plemun spacer done on a 5at, and also getting a hand tune to solve a few nagging issues with the trottleplate, rpm limiter and the Factory AFR.
But something nagging voice is wondering if I need to narrow the gap on the NGK plugs to account for thicker fuel mixture.
stock gap is .044.. im wondering if I need to go to .042 or .040 to account for what is likely to be a much higher AFR.
Thoughts ?
Old Sep 16, 2014 | 03:54 PM
ScraggleRock's Avatar
Nope
Old Sep 17, 2014 | 10:45 AM
seymore4's Avatar
m56
Osiris tuning will fix everything. I would recommend new plugs, but leave the gap alone
Old Sep 17, 2014 | 12:25 PM
maxxcool's Avatar
Done and done thank you both..
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
KallDay86
Jan 8, 2016 12:42 AM
Fox843
Nov 7, 2015 05:43 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
