Oil gasket seal
Old Oct 10, 2014 | 10:51 PM
Thanhnguyening's Avatar
Oil gasket seal
I found some threads about this, but I feel the need to post a picture about my problem. So, last night while I was driving. I hit something really hard to make the seal kinda pop out of place. Its barely leaking and when I leave my car parked through out the day, today. You will only see like a droplet of oil. Should I still get this fixed immediately and how much will it cost just to replace the seal? Is it easily replaceable if I could do it myself? Thanks guys!
Old Oct 12, 2014 | 02:07 AM
Droopy89's Avatar
Is this the side of the oil pan? Are you really low?
Old Oct 12, 2014 | 10:55 AM
brazen's Avatar
I would replace it. I replaced mine in about 45 minutes using the below seal rather than RTV. The worst part is just scraping the old RTV off the oil pan once you get it off. Just be sure to tighten all bolts to factory specs once you get the new gasket on. Good luck!
Amazon.com: Fel-Pro OS30688  Oil Pan Gasket Set: Automotive Amazon.com: Fel-Pro OS30688 Oil Pan Gasket Set: Automotive
Old Oct 12, 2014 | 01:56 PM
Lone Wolf's Avatar
Definitely fix your leak as soon as possible.
Old Oct 12, 2014 | 02:27 PM
dEnbOy.GFM's Avatar
Small leaks today = bigger leaks tomorrow.
Dallsinghjr1
Sep 17, 2023 11:25 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
f22raptor
Mar 18, 2016 08:50 AM
mbe32
Nov 13, 2015 11:09 PM
BradMD_96
Oct 6, 2015 09:31 AM
