diff whine
Old Nov 15, 2014 | 12:53 PM
Usman Ali's Avatar
diff whine
Hello,
Installed white line diff kit on my g35 and after I noticed a whine from the diff, I never had this whine before installation ...is this normal? Please help.
Old Nov 16, 2014 | 12:43 PM
Usman Ali's Avatar
Anyone??
Old Nov 16, 2014 | 01:57 PM
Blue Dream's Avatar
I drove ttrank's car solo
Did you install only bushings? Did you do the work or did someone else? My guess something's off when it was re-installed
Old Nov 16, 2014 | 07:47 PM
wuzz-upp's Avatar
I agree with Blue Dream, how about the fluid servicing, is it the proper weight and is it serviced to the proper level?
Old Nov 17, 2014 | 07:26 AM
Usman Ali's Avatar
the job was done by mechanic at a workshop, the new diff bushings with parts number: Whiteline Polyurethane Diff bushings KDT911 were installed, the old diff bushings which are silicon filled leaked this black liquid, the car is only driven 20,000 miles so i didnt get the oil changed as it was not needed.
the kit came with a sub frame bushings as well as diff upper and lower bushings. the whine is only on low speed and not on high speed...after more research i found that Polyurethane Diff bushings are harder then oem bushings and tend to give off a slight whine when car is slowing down, i also read that solid make even more whine and noise.
this kit: http://www.ebay.com/itm/like/121342887129
Old Nov 17, 2014 | 01:12 PM
gary c's Avatar
Welcome to my world, any time you install poly in any part of your car that flexes or moves you're creating noise...Gary
Old Nov 19, 2014 | 11:15 AM
Mustang5L5's Avatar
I would concur. Poly bushings tend to be a little firmer than OEM. SO you get better response in handling and such, but the trade off is an increase in NVH (noise, vibration, harshness). Just something to think about when selecting bushing materials.
Unfortunately you may have to live with it, or change back to OEM bushings.
alessandro
Oct 8, 2015 09:29 AM
myGspot
Drivetrain
Aug 11, 2015 11:58 AM
edwinisdumb15
SOCAL Meetings & Events
Aug 3, 2015 10:42 PM
whattf
Drivetrain
Jul 20, 2015 11:19 AM
