To Go or Not To GO with FI?
Old Feb 16, 2005 | 05:38 PM
Vic's Avatar
Vic
for those of you who have FI on G35, do you have any problems, maybe blown engine?
the compression ratio for G35 is pretty high.. it's 10:1. So I'm worried if I put FI, the engine will blow.
I was thinking to just go with N/A, since it does not have any risks of blown engine, but I feel that it does not produce as much power as FI.
So, should I go with FI or not?
Old Feb 16, 2005 | 05:47 PM
dwoloz's Avatar
If you can afford the parts cost, install cost and the cost of a possible engine replacement then by all means, go for it
Its all a money game
Otherwise, I would play it safe and stick with NA
Old Feb 16, 2005 | 07:13 PM
GXCLUSIV's Avatar
You can go with Stillen stage 2 supercharger, and get the 3yr.engine warranty. Cost around $5K. Problem is, you need the stillen hood.
Old Feb 16, 2005 | 08:14 PM
chops's Avatar
4 months and 2300 miles, no problems here!
I waited until I had 11k on the car to make sure I got the bugs out before blowing the warranty.
I really doubt I could go back to a n/a G now.
Power is addictive though. I could use another 100hp! Oh well!
Randy, where are you?
Old Feb 16, 2005 | 08:31 PM
GZire's Avatar
Check out the Techical forum under the forced induction section. Should be a ton of information relevant to the questions you have.
Good luck.
