fender rolled/shaved questions
Old Dec 17, 2014 | 12:41 PM
itztwinki3's Avatar
How low can I go before I have to roll or shave or do any mods to my fenders? I bought ccw rims kept the it 18s. front are 18x8.5 offset 25 and rears are 18x9.5 offset 20. I am not lowered yet. I have a set of godspeed coilovers. I want to lower the car without do any fender mods. any suggestion? I have 18x9 all around on my 01 gs300 dropped 1.5inch all around with no fender mods need. i want the same set up for the g35.
Tire size I will be running for fronts are 225/45r18 and rears will be 265/40r18
Old Dec 19, 2014 | 01:57 AM
itztwinki3's Avatar
bump
anyone?
Old Dec 19, 2014 | 06:41 AM
Lartytiejdke3's Avatar
There's not like some set amount that once you reach it then you need a roll.
Just visually see if you have enough clearance...also if you're rubbing you'll know after a few bumps or so
From what it seems you'll only need to roll the rears should you go lower
Old Dec 20, 2014 | 05:32 PM
itztwinki3's Avatar
thank you
Old Dec 30, 2014 | 04:42 PM
itztwinki3's Avatar
Okay so i changed my mind about my old set up. I just order a set of rims.
19x8.5 offset 18 (front)
19x10.5 offset 25 (rear)
what tire size do you guys recommend? how to avoid vdc from going crazy.
will i need to roll any of my fenders? I am not dropped just yet. any advice will be much appreciated thanks.
Going on my 2003 G35 Coupe.
Old Dec 30, 2014 | 08:54 PM
Urbanengineer's Avatar
Originally Posted by itztwinki3
Okay so i changed my mind about my old set up. I just order a set of rims. 19x8.5 offset 18 (front) 19x10.5 offset 25 (rear) what tire size do you guys recommend? how to avoid vdc from going crazy. will i need to roll any of my fenders? I am not dropped just yet. any advice will be much appreciated thanks. Going on my 2003 G35 Coupe.
Use the tire size calculator on the website here..
They have to be within 3% height front and back, with the back being larger than the front on staggered and even on the Sedan wheels.
helalo
Aug 10, 2015 08:21 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
st33zygill
Jul 29, 2015 10:05 PM
Soumilg
Jul 18, 2015 12:33 PM
