Low RPM During Idle After 5/16 Spacer Install
Old Jan 18, 2015 | 08:42 AM
Lartytiejdke3's Avatar
Originally Posted by G35Tdot
Yup checked them all, they were all snug. Yea removing the negative cable was the first thing I did. Wasn't too happy about my radio presets being reset but it was worth it. Idle when engine is cold seems normal though going to wait a bit then do a throttle relearn
+2 on the re learn. The pedal dance is tricky at first and took me about 15 mins to nail it but it fixed my issue of a high rpm idle when I installed a polished throttle body
Best of luck man
Old Jan 18, 2015 | 12:19 PM
G35Tdot's Avatar
Best of luck man
Thanks! Going to be doing it next weekend
Old Jan 18, 2015 | 12:54 PM
you haven't stalled out yet have you?
Old Jan 18, 2015 | 01:06 PM
G35Tdot's Avatar
Nope! but I blipped the throttle a couple of times to see if it would go back to normal but it dropped almost to the 0 after I let go of the gas which kind of scared me at first. Not sure if its suppose to do that haha
Old Jan 18, 2015 | 01:09 PM
yeah it's not lol The sooner you attempt that pedal relearn procedure the better
Old Jan 18, 2015 | 01:33 PM
G35Tdot's Avatar
I guess you're right gonna do that as soon as I have time Friday since I really only drive it on weekends its not going to be touched until then. Can't believe I messed up one of the easiest mods haha
Old Jan 18, 2015 | 03:23 PM
JKL1031's Avatar
I bet u trapped the oil filler boot between the manifold. Don't lie..
Old Jan 18, 2015 | 07:57 PM
G35Tdot's Avatar
The funny thing was it took me about 3 tries to actually get it on properly bolted and everything. I noticed the upper plenum was getting caught onto that rubber piece the second time LOL. I'm going to double check that though good point.
Old Jan 18, 2015 | 07:59 PM
make sure the hose on your intake tube is properly secured as well. lot of people forget about that
Old Jan 18, 2015 | 08:06 PM
G35Tdot's Avatar
Yup! made sure I secured all hoses before I started the car. Do you think its because I disconnected the battery for too long? Since I've been reading around and I saw people say that you can do a ECU reset by leaving your battery unplugged for a certain amount of time. Mine was not connected for a good 3 hours.
EDIT: I'll be doing the reset this Friday I'll let you guys know how it goes
Old Jan 18, 2015 | 08:11 PM
eh I really think it's because of when you touched the throttle body a bit to be honest
Old Jan 18, 2015 | 08:54 PM
ScraggleRock's Avatar
I dunno. I've cleaned my throttle body and fingered/diddled it a lot and never had any adverse affect other than one time right afterward it took a bit longer to crank before it turned over.
Old Jan 18, 2015 | 09:17 PM
that is true. You do digitally rape your tb on many occasion. I think in ops case this may be his issue though and a relearn will fix it
Old Mar 14, 2015 | 11:41 AM
G35Outlaw's Avatar
+37374759593822648484959482726364. On the re learn ...
Cskeet
Drivetrain
Dec 3, 2015 09:18 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
deathsupport
Canada
Aug 2, 2015 10:13 AM
sick_sixspeed
Jul 20, 2015 10:25 PM
